3G/WIFI/BT Hat, 3G modem and Wifi Module.
Jérôme FENWICK
New Member Posts: 1 ✭
in Peripherals
My order is coming with 3G/WIFI/BT Hat, 3G modem and Wifi Module.
but with no documentation...
The 3G Modem is working fine connected to the HAT via PCmcie.
The Wifi module is working fine connected directly to the UP Board
But the Wifi module is not working when is connected to the HAT USB Port.
So I can't have wifi and 3G as expected.
Is there a problem on the HAT USB port ?
Regards
Regards
Hi I'm also interested in have this SBC and incorporate on in 3G Cellular module and WIFI
what kind of 3g module did you use? -
WIFI should be connected to UP port because you need to provide enough current to it.
About the 3G modem, we use industrial module of Quectel ( http://www.quectel.com/product/ )
All the best
Cheers
