Unable to install Ubilinux
Hi Guys,
I have an Upboard 2GB/32GB and I cannot install Ubilinux on it. During teh installation log I get this errors:
efi: requested map not found.
esrt: ESRT header is not in the memory map.
dw_dmac INTL9C60:00: Missing DT data
Failed to find cpu0 device mode
i8042: Can't read CTR while initializing i8042
failed to execute '/lib/udev/mtp-probe' 'tmp-probe /sys/devices/pci0000_00/0000:00:14.0/usb/1-3 1 3': No Such file
failed to execute '/lib/udev/mtp-probe' 'tmp-probe /sys/devices/pci0000_00/0000:00:14.0/usb/1-2 1 2': No Such file
failed to execute '/lib/udev/mtp-probe' 'tmp-probe /sys/devices/pci0000_00/0000:00:14.0/usb/1-7.1 1 5': No Such file
failed to execute '/lib/udev/mtp-probe' 'tmp-probe /sys/devices/pci0000_00/0000:00:14.0/usb/1-7.4 1 6': No Such file
[drm:intel_parse_bios [i915]] *ERROR* undefined sequence
[drm:intel_pipe_config_compare [i915]] *ERROR* mismatch in base.adjusted_mode.crtc_clocl (expeceted 71100, found 18229)
[drm:intel_pipe_config_compare [i915]] *ERROR* mismatch in port_clock (expeceted 71100, found 18229)
Failed at step EXEC spawning /bin/playmouth: No such file or directory
[drm:chv_set_memory_dvfs [i915]] *ERROR* timed out waiting for Punit DDR DVFS request
After the full install it reboot and hangs a blue screen with 2 white boxes one in the middle of the screen and one of the top left corner and I need to power off and power on.
Please help because I have similar behaviors with Ubuntu 16.04 LTS.
I also updated the BIOS but No Way!
