UPBoard power problem.
Hello to all members of the UPcommunity.
I have a problem connecting the Upboard. I would appreciate help.
When the power is turned on, the blue LED is power on but after a few seconds it goes out and the fan is turned off too.
In that interval the screen connects but I do not have time to see what it is. I've tried with a boot usb but still with the same behavior. Also try to enter the bios configuration but see the configuration screen for one second it's power off and I can not change anything.
I do not know if it has gone wrong from the factory or is a recoverable problem. (I have another of the same characteristics and I had no problem)
Can you help me solve the problem?
Thank you very much
  • Dan O'Donovan
    Something to rule out here would be corrupted BIOS settings, I think. Can you try disconnecting your RTC battery for a few minutes, then booting the board, then try again with the battery reconnected?
  • David
    David New Member Posts: 2 ✭
    First of all thank you.
    I already tried this option and I still have the same problem.
  • Aling
    Hi Wirtex,
    We are not able to determine if it is OS related problem since we don't know what was installed. You may contact UP Shop for RMA, and we will take a look into it. Thanks!
