Windows10 Driver Problem
File:
Win10_32_20160307\Win10_32\20160307\Step4-DummyDriver(Manual)\UP_DDriver\UP_DDriver.inf
The solution is to open it in notepad and remove the substitute character at the end of the file. This invalid character is present in both the 32 and 64 bit Windows 10 1.1 driver downloads.
The driver applies to the following device hardware IDs:
ACPI\VEN_8086&DEV_2288
ACPI\VEN_8086&DEV_2289
ACPI\VEN_HAD0&DEV_22A8
Just throwing this out there in case anyone else runs into it.
that is strange
i just installed it without problems
i followed the instructions in the file
but it still shows a unknown driver
apparently no one knows what this is
i refer to another of my posts here on this forum -
If the device you're looking at is anything like the one I ran into, there appears to not be a Windows driver. I rolled it into the inf file I referenced above, since I had to edit and resign it anyway...
All this achieves is removing the yellow hardware bang from device manager.
My UP_DDriver.inf file, now reads:
[Version]
Signature="$WINDOWS NT$"
Class=System
Provider=%String0%
CatalogFile=UP_DDriver.cat
DriverVer=01/14/2016,6.0.5736.1
[Manufacturer]
%String1%=AAEON_SYS,NTAMD64
[AAEON_SYS]
%String2%=NO_DRV,ACPI\VEN_8086&DEV_2288
%String3%=NO_DRV,ACPI\VEN_8086&DEV_2289
%String4%=NO_DRV,ACPI\VEN_HAD0&DEV_22A8
%String5%=NO_DRV,ACPI\VEN_ADC&DEV_081C
[AAEON_SYS.NTAMD64]
[DriverInstall.NT]
[DriverInstall]
[NO_DRV]
[NO_DRV.Services]
AddService = , %SPSVCINST_ASSOCSERVICE% ; null service install
[Strings]
String0="AAEON Technology Inc."
String1="AAEON Technology Inc."
String2="AAEON DEV_2288"
String3="AAEON DEV_2289"
String4="AAEON DEV_22A8"
String5="TI ADC081C021 ADC"
SPSVCINST_ASSOCSERVICE = 0x00000002 -
For anyone who is wondering:
These are PWM controllers on the CherryTrail SoC (connected to HAT header pins 32 and 33):
This is a device entry in the ACPI table which was added to enable HDMI Audio on Linux, but isn't actually needed now (as far as I know):
This is an 8-bit ADC on the UP board, connected internally to I2C bus #3 and externally to HAT header pin 7:
String5="TI ADC081C021 ADC" -
This is an old thread but I wanted to add what worked for me...
Disable Windows 10 enforcement of driver signatures, then follow the instructions in the included doc file. Windows 10 enforcement of driver signatures will be reenabled automatically when you reboot after installing the driver.
To disable:
1. Click the windows Start menu and select Settings
2. Click Update and Security
3. Click on Recovery
4. Click Restart now under Advanced Startup
5. Click Troubleshoot
6. Click Advanced options
7. Click Startup Settings (if this does not appear, there should be a link for more options. It will then appear.
8. Click Restart (Restarting will bring up another screen with various startup options)
9. On the Startup Settings screen, press 7 or F7 to disable driver signature enforcement.Now, follow the included instructions for installation and the responses shown in the document will match what you see. Once you install the driver and restart the computer again the driver signature enforcement will b re-enabled.
- 105 Announcements & News
- 185 Welcome Developers!
- 49 Tech Updates
- 693 UP Products
- 11 UP 7000
- 10 UP Xtreme i12
- 11 UP Squared Pro 7000
- 19 UP Squared V2
- 59 UP 4000
- 35 UP Squared 6000
- 60 UP Squared Pro
- 143 UP Xtreme
- 837 UP Squared
- 222 UP Core
