Webkit Overlay of HDMI Stream In/Out
Hi Up Squared Team,
I would be soooo glad if someone could implement a Chrome Overlay on FPGA between HDMI In and HDMI Out.
Let me explain:
In 2010, Adafruit created NeTv and OpenSource the code
https://www.adafruit.com/product/609
This card forward HDMI In to the HDMI Out even if the signal is crypted. A Transparent Webkit full screen is set as an overlay of the image.
There is so many usecase ! For instance I forward my security webcam and notifications on top of the screen:
http://blog.encausse.net/2016/11/28/television-2-0-part-3/
But a 2010 card is very slow (CSS transition works but not the video). The Up Squared would be so impressive with this feature ! So much usage for Home Automation with Personal Assistant, Elders, etc ...
Thanks.
Let me explain:
Thanks.
Thanks for your suggestion.
we cannot support this application, FPGA cannot capture the HDMI signal.
the alternative solution would be to use a HDMI-to-USB3 capture device and add this overlay on the captured video stream before sending the video out to UP^2 HDMI. However, it need a strong software effort. We don't have plan to do it now.
So what is the use case of an hdmi in and an hdmi out ?
But there is no device (only NeTV) that have hdmi in/out to overlay the information on the Screen.
Elders needs to know someone ring at the door, or event reminder, etc ... this features would helps to "connect" TV.
I like the way NeTV solve that by putting a Chrome layer that's very handy
I found this topic, and it's related to a question I have. So I thought I'd add this question:
You mentioned using an HDMI to USB3 capture device. Would the board be able to feed in HD 1080p video through the HDMI to USB 3 device while sending it over the web through streaming (through browser or Skype-like apps) using Windows 10 OS without the hardware being overloaded?
Hi AlingWu,
Thank you, this is great to know it will handle it. I was actually looking at the same capture device as the one you you posted above as it is a high quality device.
In the product specs tab you can find a list of compatible and uncompatible USB3 controllers https://www.startech.com/uk/AV/Converters/Video/usb-3-0-video-capture-device-hdmi-dvi-vga~USB3HDCAP
It reads: This product is not compatible with Etron USB controllers, or ASMedia 1042 / 1042A USB controllers. Confirmed compatible USB 3.0 host controllers: Intel, Renesas (NEC), VIA, AMD, Fresco FL1100
Incompatible USB 3.0 host controllers: ASmedia, Etron
Can you confirm UP^2 will have USB3 controllers compatible per these specs? (Win 10 OS preferably).
Thank you!!!
My bests
For UP & UP Squared, all USB3 ports are directely connected to Intel CPU so there won’t be any problem reported. (Confirmed compatible USB 3.0 host controllers: Intel, …)
We didn't really check startech solution ourself, I just simply googled it. :-)
If you have nice test result, please share in UP community.
