Ubuntu stop working
Friday I installed Ubuntu and all looked good. Today the board is not responding anymore.
At the beginning It showed the grub and crashed. Now it seems it doesn't work at all. No screen output, just the blue light.
I tried:
- to use a usb with a live distribution of Ubuntu but the board does not see it;
- to turn off and turn on the power to the board;
- to change HDMI cable
Any idea?
  • Dan O'Donovan
    Dan O'Donovan Posts: 241 admin
    Hi
    Sorry for the late reply. In case its still useful, could you try to disconnect the RTC battery for a few minutes, then power up the board (still with the battery disconnected). Then reconnect the battery and try again.
    In case the issue is caused by corrupted or invalid BIOS settings, this should reset them. If that doesn't work, then I'd suggest contacting the UP shop to see if the board should be returned (if you haven't done so already).
    -Dan
