eMMC and buildroot - ACPI mode not detected
I tried to use the eMMC with the latest stable buildroot (kernel 4.19) but the eMMC was not detected (I enabled the SDHCI_ACPI option).
I finally managed to use it by swithing the mode to PCI in the BIOS.
So I have a few questions:
- Is ACPI a better mode? If so, why? (I didn't find anything relevant for now).
BTW, if someone managed to enable the eMMC detection with ACPI mode, I would be please to know what I missed on the kernel configuration ![]()
Hi @sivizue ,
The only one kernel supported by our team is the kernel 4.15:
https://wiki.up-community.org/UbuntuIt is supported for Ubuntu 16.04 and Ubuntu 18.04 as well.
Please, confirm you are able to install the supported Ubuntu + kernel in your UP board. -
The board is working like a charm with both Ubuntu 16.04, Ubuntu 18.04 and Debian buster (testing). I already try the 4.14 and 4.15 version, but I get the same behavior. I suspect that another option shall be enabled to detect the eMMC in ACPI mode properly, but I can figure out which one.
BTW, it is also working properly with buildroot if the eMMC is configured in PCI mode in the BIOS (hence my question ACPI vs PCI)
Hi @sivizue ,
For ACPI option, I think kernel configuration is necessary as well.
You said, you get CONFIG_MMC_SDHCI_ACPI enable, right?
That configurations depends on CONFIG_MMC_SDHCI && CONFIG_ACPI && CONFIG_PCI. Did you enable them for your kernel? -
Theses configurations are enabled (in fact, I don't think that it is possible to enable MMC_SDHC_ACPI without the others).
Anyway, thank you for your help
Hi @sivizue ,
If the MMC controller is configured in ACPI mode in the BIOS, then you should see the ACPI directory here:
cat /sys/bus/acpi/devices/80860F14:00/statusThat is the first test to be sure the ACPI mode is set correctly via BIOS settings.
Could you please confirm that to me?
