[SOLVED] CPU temperature
New Member Posts: 8
edited January 2019 in UP Board Linux
How can we retrieve the current CPU temperature of the UP Board through linux command line? Is there any information into /sys/?
Regards,
Welcome!
  • New Member Posts: 348 ✭✭✭
    Hi @jbaptiste ,
    One easy way is to install lm-sensors and check your current temperature for the cores:
    sudo apt-get install lm-sensors
    Then, run 'sensors' command and see something like that:
    acpitz-virtual-0
    Adapter: Virtual device
    temp1: +0.0°C (crit = +90.0°C)
    coretemp-isa-0000
    Adapter: ISA adapter
    Core 0: +50.0°C (high = +90.0°C, crit = +90.0°C)
    Core 1: +51.0°C (high = +90.0°C, crit = +90.0°C)
    Core 2: +49.0°C (high = +90.0°C, crit = +90.0°C)
    Core 3: +47.0°C (high = +90.0°C, crit = +90.0°C)
  • New Member Posts: 14
    Alternatively, you can also do:
    cat /sys/devices/platform/coretemp.0/hwmon/hwmon0/*_input
    Hi @rchauvin ,
    Thanks for the alternative!
Welcome!
