PWM0 Example Not Working in Ubuntu 16.04
I'm trying to get PWM0 working on my Up2 board, following the example here:
https://wiki.up-community.org/Pinout_UP2
I have Ubuntu 16.04.5 installed, and otherwise followed the instructions here:
The GPIO works on that pin (Linux pin number 468), but when I run the PWM example commands, nothing happens.
Any suggestions? Thanks.
Hi @skcolb ,
The best and easy way is to check how the pin level is changing:
$ echo 0 > /sys/class/pwm/pwmchip0/export
$ echo 3413333 > /sys/class/pwm/pwmchip0/pwm0/period
$ echo 1706667 > /sys/class/pwm/pwmchip0/pwm0/duty_cycleBefore active the pin: cat /sys/class/pwm/pwmchip0/pwm0/enable
$ echo 1 > /sys/class/pwm/pwmchip0/pwm0/enable
After ative the pin: cat /sys/class/pwm/pwmchip0/pwm0/enableThen, you should see how the pin is off and on when you want.
Also, you could try to conenct a logic analyser in your pin to see something like in the attached pic.
Cheers!
