Boot an upcore over network PXE
Having several up-core, I need to boot in PXE via my dongle usb / ethernet.
The PXE has been activated in the bios and normally my bios is up to date with the latest version.
I have tried several but none is recognized and no network is not functional.
Which USB / Ethernet dongles are functional? Can you provide a listing?
Can the PXE boot be done on any usb port?
Is there a version of bios before it works?
i have used this dongle that usually works fine with any bios : https://www.amazon.fr/Plugable-Adaptateur-Gigabit-Ethernet-AX88179/dp/B00AQM8586
by the i wanna add that i have tried to boot using ipxe (gpxe was too old) on an usb key but it do not allow to boot over pxe.
Thank you in advance for your return.
Thierry
Hello Tgayet,
In order to use PXE on UP Core, you need to use this carrier board: https://up-shop.org/up-core/202-up-core-carrier-board-high-speed.html
PXE functionality wasn't tested with a standard USB to ethernet dongle, as the BIOS implementation is specific to the Network chip included in the carrier board above.
