Help me, please - How to fix Up board on 7 inchs TFT LCD
Dear you,
1. I tried to follow documents at the link to fix Up board at the back of display as the instruction but I can not see the hole to screw 4 screws or bolts at the back of the display
https://up-shop.org/up-peripherals/11-lcd-touchscreen-display-kit-7-.html.
2. How to connect 6 pins flat cable - JP1 with connector J6 at the right, bottom of board (connector has red circle on the picture). It very hard to lock cable and connector.
My contact: Hungnmpcu@gmail.com.
Thanks for carring my problems, have a good day !
Hello
I tried to follow documents at the link to fix Up board at the back of display as the instruction.
Hi timpage,
Could you tell me more details or send the document to my email on the thread, there are no documents in yours above link. Thanks for listening,
Sincerely yours,
Hung nguyen manh - Hungnmpcu@gmail.com. -
Hi all,
Please check the attached file to understand how to set the screen up.
Cheers!
Dear ccalde and timpage,
Thank you very much, I solved the problem about the connection and now I am trying to install ubuntu with LCD.
have a good day,
