name/reference for UP-CORE power connector?
BRUSSIEUX
New Member Posts: 10 ✭✭
UP-CORE can be powered-on by shorting the 2 contacts of CN33 connector.
The reference of this connector on the docs is "1201-700-02S" : it looks like a molex microblade, but has anyone got a reference/ reseller for the mating (female) connector?
regards
regards
...answering my own post, i tested these connectors:
they work well & i can confirm they can be used for the UP-CORE power switch.
(1.25 mm JST 2 Pin Micro Electrical Male and Female Connector Plug with 10 cm Wire Cable)
this topic is closed...
CN33 as power connector! Nice
