Pfsense 2.4 release doesn't work
hamador
New Member Posts: 3 ✭
Since pfsense 2.4 is ready, unable to install it on up2board (following these recommendations (eMMC disabled in the bios): https://up-community.org/wiki/PfSense).
Indeed, pfsense freeze on the startup with these messages:
Image used: https://nyifiles.pfsense.org/mirror/downloads/pfSense-CE-memstick-2.4.0-RELEASE-amd64.img.gz
Support: USB stick
Best regards,
atkbd0: [GIANT-LOCKED] ppc0: cannot reserve I/O port range
Support: USB stick
Best regards,
I have the same messages on my UP Squared that boots pfSense 2.4 Release.
atkbd0 is just the keyboard.
ppc0 is the parallel port, which doesn't exist.
These are the close to the last messages before the display driver loads. So perhaps there is an issue with it.
For the record, I reset the BIOS 1.8 to factory defaults, disabled eMMC and then went to install pfSense 2.4 Release. All went fine.Eric Duncan - UP Evangelist - My thoughts are of my own free will
I just retry (bios version: UPC1BM0X) a reset & disable eMMC with pfSense-CE-memstick-2.4.1-RELEASE-amd64.img & I have the same error
Best regards, -
hamador wrote:Hello,
Best regards,
Oops. That is the BIOS for the UP Board, not the UP2 Squared! All of my pfSense and other firewall tests have been on the UP2 Squared that has two NICs and uses the Intel Apollo Lake chipset. This was the documentation added
The standard raspberry-pi sized UP Board only has a single NIC and uses the Intel Cherry Trail chipset. A single network port is not advised by the pfSense community since you'd have to rely on vlan tagging on your shared trunk.
I have not tested pfSense directly on the UP Board for that reason. The reason I added Partial support in the Wiki pages for the Cherry Trail chipset was that I got FreeBSD 11 installed on it earlier, which is the base for pfSense 2.4. So I assumed it would boot with pfSense since all other freebsd+pfsense tests work out the same.
I'll try to find some time to validate it again later this week.Eric Duncan - UP Evangelist - My thoughts are of my own free will
Yes, I have UP Board but I have also a Ethernet port via USB (3.0). This is why I try to use pfsense.
Best regards,
