Overheating?
                    Kenneth Coley
                    New Member Posts: 37 ✭
                    Anyone else notice high temperature on M.2 WiFi or mPCIe drive modules?  I don't have a mechanism to give exact surface temperature
but they are both extremely hot to touch.
            Seriously, nobody??? Not even a response from UP themselves?
            You'd have to define "extremely hot" a bit more precisely than that, like is it hot enough to burn you? If it's just hot, but not enough to burn you, then it probably is normal.
            My CPU is hitting the high 80s (ºC) under load and I find that atrocious...
