Error while installing the wifi driver. (RTL8188CUS)
bruce
New Member Posts: 15 ✭
in Peripherals
Hi guys. I have purchased the EDUP wifi dongle from Amazon. which has `
please help. Thanks a lot.
RTL8188CUS` drivers. I have downloaded the zip file (using my windows machine) and then transferred it to the UP board using usb flash drive. I extracted the zip file on the desktop, which contains the `
install.sh` file. to install the drivers on my UPboard, I used the command
sh install.shbut I am getting the errors and not able to install the wifi drivers.
makefile:150: recipe for target 'sub make' failed
make[2]:***[sub-make]error-2 ................................
compile make driver error:2 please check error mesg
when I type
lsusb
it shows me
but when I enter the codeBus 001 Device 003: ID 0bda:8176 Realtek Semiconductor Corp. RTL8188CUS 802.11n WLAN Adapterlsmod | grep rtl
it doesn't give me any result.
I was also following the following link https://crunchbang.org/forums/viewtopic.php?id=40015https://crunchbang.org/forums/viewtopic.php?id=40015
