SATA port multiplier works
Per Mejdal Rasmussen
New Member Posts: 19 ✭
I have tested my SATA port multiplier, and it works. It is however not hot-pluggable.
[ 3.018801] mmc0: SDHCI controller on PCI [0000:00:1b.0] using ADMA 64-bit [ 3.018840] sdhci-pci 0000:00:1c.0: SDHCI controller found [8086:5acc] (rev b) [ 3.023689] mmc1: SDHCI controller on PCI [0000:00:1c.0] using ADMA 64-bit [ 3.023748] sdhci-pci 0000:00:1e.0: SDHCI controller found [8086:5ad0] (rev b) [ 3.023759] sdhci-pci 0000:00:1e.0: enabling device (0000 -> 0002) [ 3.028353] mmc2: SDHCI controller on PCI [0000:00:1e.0] using ADMA 64-bit [ 3.030819] ahci 0000:00:12.0: version 3.0 [ 3.031596] SSE version of gcm_enc/dec engaged. [ 3.041329] ahci 0000:00:12.0: AHCI 0001.0301 32 slots 2 ports 6 Gbps 0x3 impl SATA mode [ 3.041333] ahci 0000:00:12.0: flags: 64bit ncq sntf pm clo only pmp pio slum part deso sadm sds apst [ 3.042486] scsi host0: ahci [ 3.042767] scsi host1: ahci [ 3.042855] ata1: SATA max UDMA/133 abar m2048@0x81335000 port 0x81335100 irq 367 [ 3.042858] ata2: SATA max UDMA/133 abar m2048@0x81335000 port 0x81335180 irq 367 [ 4.475278] ata1.01: SATA link up 3.0 Gbps (SStatus 123 SControl 320) [ 4.475316] ata1.02: hard resetting link [ 4.788954] ata1.02: SATA link down (SStatus 0 SControl 320) [ 4.791084] ata1.00: ATA-8: SAMSUNG HD501LJ, CR100-10, max UDMA7 [ 4.791089] ata1.00: 976773168 sectors, multi 16: LBA48 NCQ (depth 31/32), AA [ 4.793272] ata1.00: configured for UDMA/133 [ 4.813953] ata1.01: ATA-8: SAMSUNG HD501LJ, CR100-10, max UDMA7 [ 4.813959] ata1.01: 976773168 sectors, multi 0: LBA48 NCQ (depth 31/32), AA [ 4.816116] ata1.01: configured for UDMA/133 [ 4.816188] ata1: EH complete [ 4.817002] scsi 0:0:0:0: Direct-Access ATA SAMSUNG HD501LJ 0-10 PQ: 0 ANSI: 5 [ 4.848243] scsi 0:1:0:0: Direct-Access ATA SAMSUNG HD501LJ 0-10 PQ: 0 ANSI: 5 [ 4.889464] sd 0:1:0:0: [sdb] 976773168 512-byte logical blocks: (500 GB/466 GiB) [ 4.889634] sd 0:0:0:0: [sda] 976773168 512-byte logical blocks: (500 GB/466 GiB) [ 4.889646] sd 0:1:0:0: [sdb] Write Protect is off [ 4.889649] sd 0:1:0:0: [sdb] Mode Sense: 00 3a 00 00 [ 4.889684] sd 0:1:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA [ 4.889703] sd 0:0:0:0: [sda] Write Protect is off [ 4.889706] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00 [ 4.889739] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA [ 4.981585] sdb: sdb1 sdb2 [ 4.981859] sda: sda1 sda2 [ 4.982906] sd 0:1:0:0: [sdb] Attached SCSI disk [ 4.983251] sd 0:0:0:0: [sda] Attached SCSI disk
What is the model you have used?
Regards -
The port multiplier i an ONE eCube IIONE eCube II.
Thanks Per,
This will go a long way in my DIY NAS project.
