Simple Kernel Loading Isse
                    Yuan Feng
                    New Member Posts: 5 ✭
                    Hi Everyone,
I wrote a simple kernel which is unix-based. How can I use upboard to boot with this OS image.
Could any one tell me the steps?
Many Thanks
Many Thanks
            Hi Michael,
 The question is very generic and the step may vary depending on the distribution you are using.
 Is it a Unix or Linux system?
 Does it support EFI boot?
 Yes, I support EFI. I put this on my thinkpad notebookt and it works. Thinkpad is sandybridge chip.
 Linux system based.
            The solution I use is
 add the following to /boot/grub/grub.cfg on ubuntu
 menuentry ' '{
 multiboot /boot/kernel....
 It works on my thinkpad, but does not work on up board. It cannot display anything.
            The code I am using is similar to this
 const char *str = "my first kernel";
 char *vidptr = (char*)0xb8000; //video mem begins here.
 unsigned int i = 0;
 unsigned int j = 0;
 while(j < 80 * 25 * 2) {
 /* blank character */
 vidptr[j] = ' ';
 vidptr[j+1] = 0x07;
 j = j + 2;
 j = 0;
 /* this loop writes the string to video memory */
 while(str[j] != '\0') {
 vidptr = str[j];
 vidptr[i+1] = 0x07;
 ++j;
 i = i + 2;
 return;
            Hi michaelyuanfeng,
 If you are compiling a custom kernel for ubuntu I would suggest to start from our kernel on launchpad: https://launchpad.net/~ubilinux/+archive/ubuntu/up
 Also, to simplify the installation of the new kernel you should try to compile with the option to create a deb package.
 You can then easily install with dpkg your new kernel from a ubuntu 14.04/16.04 system already installed in the UP board.
