WAN communications HAT
Isabel Laycock
New Member Posts: 1 ✭
Hello all,
I would like to take this opportunity to introduce you to a new WAN communications HAT which provides a HSPA wireless interface for the UP board.
The PiloT is able to communicate with the UP board using serial or USB communications, with separate channels for control, data and location data. The PiloT also provides location information using an on-board GNSS solution. It has been tried and tested with the UP board and is compatible.
You can find more information on the PiloT here.
Furthermore, if the PiloT sounds like it could be of use to you or any applications you are working on; please don’t hesitate to get in touch at isabel.laycock@linkwave.co.uk.
I look forward to hearing your initial opinions of the PiloT and welcome any constructive feedback.
Kind regards,
Isabel Laycock
Linkwave Technologies
Kind regards,
Isabel Laycock
Hi Isabel
Thanks very much for the post. It's great to get confirmation of new HATs which have been verified with the UP board.
Would you mind adding this HAT to the list on this wiki page: https://up-community.org/wiki/Verified_HATs?
Many thanks,
-Dan
