How to use Hailo 8 in a B-Key?
Team0
Team0 New Member Posts: 3
I would like to use a Hailo 8 under Ubuntu in the Up Squared Pro M.2 B-Key, but it seems that the device is not recognized: hailortcli scan tells me that it finds nothing. I have already got it to work on the M-Key.
Can you give instructions on how to use it in the B-Key?
Best Answer
  • Team0
    I have also tried it with another device in the B-Key, but it doesn't work as well. This device has also worked in the M-Key before.
  • HarryChiu
    HarryChiu New Member Posts: 223 ✭✭✭
    edited December 2024
    Hi @Team0
    Sorry for late reply.
    Which Hailo-8 module are you using?? (e.g. module number)
    Harry Chiu
  • Team0
    Hello @HarryChiu,
    Thank you for your reply. I use a Hailo-8™ M.2 2280 B+M key, that I bought in the up-shop: https://up-shop.org/default/hailo-m2-key.html
    When connected to the M-Key, I can run lspci -v -d 1e60:2864 that outputs Vendor Specific Information: ID=1556 among other text, here is the full output:
    01:00.0 Co-processor: Device 1e60:2864 (rev 01)
        Subsystem: Device 1e60:2864
        Flags: bus master, fast devsel, latency 0, IRQ 22
        Memory at 91604000 (64-bit, prefetchable) [size=16K]
        Memory at 91608000 (64-bit, prefetchable) [size=4K]
        Memory at 91600000 (64-bit, prefetchable) [size=16K]
        Capabilities: [80] Express Endpoint, MSI 00
        Capabilities: [e0] MSI: Enable- Count=1/1 Maskable- 64bit+
        Capabilities: [f8] Power Management version 3
        Capabilities: [100] Vendor Specific Information: ID=1556 Rev=1 Len=008 <?>
        Capabilities: [108] Latency Tolerance Reporting
        Capabilities: [110] L1 PM Substates
        Capabilities: [128] Alternative Routing-ID Interpretation (ARI)
        Capabilities: [200] Advanced Error Reporting
        Capabilities: [300] Secondary PCI Express
        Kernel driver in use: hailo
        Kernel modules: hailo_pci
    Any more info required?
    Best regards
