My SBC (up squared V2) is not starting up, how to troublshoot ?
shujat
New Member Posts: 4 ✭
All 5 LEDs are turning up, but no display and USB ports working, does any one have an idea how to troubleshoot ?
Best Answer
Hi @shujat
Please try the following methods:
Please check if the CN14 is properly connected.
You can try unplugging and reconnecting it.Please check if the RTC battery still has power. Use a multimeter to measure the voltage at CN14.
The voltage should be approximately 2.8V or higher.
Harry Chiu -
