Unable to findout the swd pins in UP Xtreme edge compute kit to program the STM32 mcu
I am using UP Xtreme edge compute i5 kit and trying to program the STM32F103C8 MCU which is available in the UP Xtreme kit via ST link V2. but i'm unable to find out the debugging pins like jtag/swd pins on STM32. can anyone please fix this problem
Thank you
Hi @babu
Please refer to the link.
https://github.com/up-board/up-community/wiki/Pinout_Xtreme_MCUBut these two pins are not connected to the external terminal block.
Harry Chiu -
yes @HarryChiu sir , i got those pins, and i want access those pins externally, is it possible ?
if it is possible let me know, in out of 16GPIO pins which pins i want to use ? -
Hi @babu
These two pins are not connected to the external terminal block.
Or you can modify the internal wiring yourself.Another method is to add 2 wire on HAT connector and pull it out of shell.
Please refer to the fig as below. It is the spec of HAT cable.
Harry Chiu
