Bluetooth and WiFi in UP SQUARED 6000 EDGE KIT
mohan
mohan New Member Posts: 7
How to check Bluetooth commands in UP SQUARED 6000 EDGE KIT which comes from other BLE device? Can you please give me solution with Program?
How to send Wi-Fi commands from UP SQUARED 6000 EDGE KIT? Please give me proper guidance?
  • HarryChiu
    HarryChiu New Member Posts: 214 ✭✭✭
    edited June 2024
    Hi @mohan
    To assist you with your inquiries regarding the UP SQUARED 6000 EDGE KIT, we need some additional information:
    1. Bluetooth and Wi-Fi Modules:
    Could you please provide the models of both the Bluetooth and Wi-Fi modules you are using??
    1. Command Requirements:
    Why do you need these commands?? For certification??
    Harry Chiu
  • mohan
    Hi Harry,
    Thank you for your prompt response. Please find the requested information below:
      Bluetooth Module: Intel® Wireless-AC 9260 with Bluetooth 5.0
      Wi-Fi Module: Intel® Wireless-AC 9260 with Wi-Fi 802.11ac
    2. Command Requirements:
    We need these commands to enable remote control and monitoring of devices connected to the UP Squared 6000 Edge Kit via Bluetooth. Specifically, our use case involves developing a home automation system where various household devices will be controlled through Bluetooth commands. The UP Squared 6000 Edge Kit will receive these commands from another BLE device and toggle GPIO pins to control relays, lights, and other appliances.
    The primary reasons for implementing these commands are:
    1. Functional Requirements: The commands will facilitate turning devices on/off, adjusting settings, and receiving status updates from sensors connected to the GPIO pins.
      Certification Needs: We aim to achieve Bluetooth SIG certification to ensure interoperability and compliance with industry standards for our BLE devices, which is crucial for market acceptance and regulatory compliance.
    We hope this information is sufficient to address your inquiries. If you require any additional details, please let us know.
    Mohan
    Best regards,
  • HarryChiu
    Hi @mohan
    Sorry, no got the point, could you elaborate it?
    And, please help point out is for what Bluetooth SIG test case???
    Harry Chiu
