SanDisk storage only reading 30.6 MB capacity after board reset
Hello, we have a few UP-CHT01-A20-0432-A11 boards that accidentally had the reset button pressed, and it wiped the Sandisk eMMC storage. When we went to reinstall Ubuntu Linux on mmcblk0, the capacity only reads as 30.6 MB now instead of 32 GB as expected. Does anyone know why this happens and how to fix it? We have tried updating the BIOS to UPC1DM23 but it didn't change this behavior.
I've attached a log from Ubuntu's boot-repair tool below in case it is helpful. Thanks in advance for your assistance!
boot-repair-4ppa130 [20210921_1938]
============================== Boot Info Summary ===============================
=> No boot loader is installed in the MBR of /dev/mmcblk0.
sda: ___________________________________________________________________________
File system: iso9660
Boot sector type: Unknown
Boot sector info:
Operating System:
Boot files: /boot/grub/grub.cfg
================================ 0 OS detected =================================
============================ Architecture/Host Info ============================
CPU architecture: 64-bit
Live-session OS is Ubuntu 64-bit (Ubuntu 18.04.5 LTS, bionic, x86_64)
===================================== UEFI =====================================
BIOS is EFI-compatible, and is setup in EFI-mode for this live-session.
efibootmgr -v
BootCurrent: 0001
Timeout: 1 seconds
BootOrder: 0001
Boot0001* UEFI: Memorex USB Flash Drive PMAP, Partition 1 PciRoot(0x0)/Pci(0x14,0x0)/USB(6,0)/USB(0,0)/HD(1,MBR,0x483122d5,0x35d8,0x1340)..BO
This session has been detected as 'live' because /proc/cmdline contains (boot=casper)
This session has been detected as 'live' because df -Th / contains overlay
============================= Drive/Partition Info =============================
Disks info: ____________________________________________________________________
Partitions info (1/3): _________________________________________________________
Partitions info (2/3): _________________________________________________________
Partitions info (3/3): _________________________________________________________
fdisk -l (filtered): ___________________________________________________________
Disk mmcblk0: 30.6 MiB, 32096256 bytes, 62688 sectors
Disk sda: 29.3 GiB, 31457280000 bytes, 61440000 sectors
Disk identifier: 0x483122d5
Boot Start End Sectors Size Id Type
sda1 * 0 4284223 4284224 2G 0 Empty
sda2 13784 18711 4928 2.4M ef EFI (FAT-12/16/32)
parted -lm (filtered): _________________________________________________________
sda:31.5GB:scsi:512:512:unknown:Memorex USB Flash Drive:;
mmcblk0:32.1MB:sd/mmc:512:512:unknown:MMC SDM032:;
blkid (filtered): ______________________________________________________________
NAME FSTYPE UUID PARTUUID LABEL PARTLABEL
sda iso9660 2020-08-06-22-59-01-00 Ubuntu 18.04.5 LTS amd64
├─sda1 iso9660 2020-08-06-22-59-01-00 483122d5-01 Ubuntu 18.04.5 LTS amd64
└─sda2 vfat EC34-71CF 483122d5-02 Ubuntu 18.04.5 LTS amd64
mmcblk0
df (filtered): _________________________________________________________________
Avail Use% Mounted on
sda 0 100% /cdrom
Mount options: __________________________________________________________________
sda ro,noatime,nojoliet,check=s,map=n,blocksize=2048
====================== sda/boot/grub/grub.cfg (filtered) =======================
Try Ubuntu without installing
Install Ubuntu
OEM install (for manufacturers)
Check disc for defects
==================== sda: Location of files loaded by Grub =====================
GiB - GB File Fragment(s)
?? = ?? boot/grub/grub.cfg 1
======================== Unknown MBRs/Boot Sectors/etc =========================
Unknown BootLoader on sda
00000000 45 52 08 00 00 00 90 90 00 00 00 00 00 00 00 00 |ER..............|
00000010 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
00000020 33 ed fa 8e d5 bc 00 7c fb fc 66 31 db 66 31 c9 |3......|..f1.f1.|
00000030 66 53 66 51 06 57 8e dd 8e c5 52 be 00 7c bf 00 |fSfQ.W....R..|..|
00000040 06 b9 00 01 f3 a5 ea 4b 06 00 00 52 b4 41 bb aa |.......K...R.A..|
00000050 55 31 c9 30 f6 f9 cd 13 72 16 81 fb 55 aa 75 10 |U1.0....r...U.u.|
00000060 83 e1 01 74 0b 66 c7 06 f3 06 b4 42 eb 15 eb 02 |...t.f.....B....|
00000070 31 c9 5a 51 b4 08 cd 13 5b 0f b6 c6 40 50 83 e1 |1.ZQ....[...@P..|
00000080 3f 51 f7 e1 53 52 50 bb 00 7c b9 04 00 66 a1 b0 |?Q..SRP..|...f..|
00000090 07 e8 44 00 0f 82 80 00 66 40 80 c7 02 e2 f2 66 |..D.....f@.....f|
000000a0 81 3e 40 7c fb c0 78 70 75 09 fa bc ec 7b ea 44 |.>@|..xpu....{.D|
000000b0 7c 00 00 e8 83 00 69 73 6f 6c 69 6e 75 78 2e 62 ||.....isolinux.b|
000000c0 69 6e 20 6d 69 73 73 69 6e 67 20 6f 72 20 63 6f |in missing or co|
000000d0 72 72 75 70 74 2e 0d 0a 66 60 66 31 d2 66 03 06 |rrupt...f`f1.f..|
000000e0 f8 7b 66 13 16 fc 7b 66 52 66 50 06 53 6a 01 6a |.{f...{fRfP.Sj.j|
000000f0 10 89 e6 66 f7 36 e8 7b c0 e4 06 88 e1 88 c5 92 |...f.6.{........|
00000100 f6 36 ee 7b 88 c6 08 e1 41 b8 01 02 8a 16 f2 7b |.6.{....A......{|
00000110 cd 13 8d 64 10 66 61 c3 e8 1e 00 4f 70 65 72 61 |...d.fa....Opera|
00000120 74 69 6e 67 20 73 79 73 74 65 6d 20 6c 6f 61 64 |ting system load|
00000130 20 65 72 72 6f 72 2e 0d 0a 5e ac b4 0e 8a 3e 62 | error...^....>b|
00000140 04 b3 07 cd 10 3c 0a 75 f1 cd 18 f4 eb fd 00 00 |.....<.u........|
00000150 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
000001b0 94 80 00 00 00 00 00 00 d5 22 31 48 00 00 80 00 |........."1H....|
000001c0 01 00 00 82 e0 fd 00 00 00 00 40 5f 41 00 00 fe |..........@_A...|
000001d0 ff ff ef fe ff ff d8 35 00 00 40 13 00 00 00 00 |.......5..@.....|
000001e0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
000001f0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 55 aa |..............U.|
00000200
=============================== StdErr Messages ================================
File descriptor 63 (pipe:[80550]) leaked on lvs invocation. Parent PID 7838: /bin/bash
Suggested repair: ______________________________________________________________
The default repair of the Boot-Repair utility would not act on the boot.
Hi @jon,
I am not sure how the button on the UP board will wipe the eMMC storage. Please follow this steps to wipe the eMMC:
- Flash Ubuntu OS on USB
- Plug in USB on UP board and power on
- Select "Try Ubuntu"
- When system boots, open terminal and type 'sudo gparted'
- On the gparted GUI you will find a wide box with /dev/mmcblk0 and the storage capacity written under
- Right click on the box and select unmount
- Right click on it and select delete for all partitions (/dev/mmcblk0p1 and /dev/mmcblk0p2)
- All partitions should be 'unallocated'
The partitions will be deleted and you will have an empty eMMC. Power off and the storage capacity should be correct.
Hi @camillus,
Even after rebooting and using Ubuntu on a USB drive, the mmcblk0 partition only shows as 30.6 MB in capacity. There are no partitions on the device anymore. Please let me know if there is anything else to potentially try. Is there another issue that could have caused this to happen, such as a power fluctuation? Thanks again.
Hi @jon ,
Can you boot into BIOS menu, Go to Chipset > North Bridge and make a screenshot of the memory information shown there.
Hi @camillus, any ideas on what might be causing this?
Jon -
Can you please also show the output of df -h from the terminal.
Sorry if this is a reply to a very old thread but maybe it would help someone who is facing the same issue again. 30.6MB recognition for Sandisk memory card capacity shows that the controller inside does not see the NAND (physically). In another word, the card is defective and needs to be replaced. However, if you lost some important information on it, there is a proper way to restore that data.
