USB no 5V - hdd connection impossible
Tone
New Member Posts: 13 ✭
Im having between 4,86 - 4,74 V (which is out of spec) on all my usb ports (no other peripherie are connected to the upboard).
However, this is too less voltage to any of my hdds, even these with external power.
How can I fix this?
Check whether your power adapter's output voltage is less than 5V.
Refer to this topic:How to power UP board with battery to read 2 USB devices -
@rogertsai(AAEON) said:
@ToneCheck whether your power adapter's output voltage is less than 5V.
Refer to this topic:How to power UP board with battery to read 2 USB devices geometry dash scratchThanks for sharing
