UP Connect Plus 5G module standalone?
DoSc
New Member Posts: 2 ✭
Hi all,
is it possible to use the UP Connect Plus i210-IT as 5G gateway with TSN without using the UP Core device?
Thanks in advance ![]()
Hi again,
as far as I could investigate a standalone operation shoud not be possible. A Core Plus or Xtreme host device is madatory. It seems pretty good technology, but it is a little bit sad that there is not too much documentation about it. The datasheet online contains only sparse data.
Is there a real datasheet or manual available somehow?
Which 5G module was used for testing? Which are compatible? Only the Fibocom FM150-AE? What is with SIMCom or Quectel M.2 modules?
Maybe someone could give a short feedback.
Thanks a lot
