GPU openVINO plugin failure when UP2 Atom board is headless in Ubuntu)
have installed XRDP on Up2 board running Ubuntu 16.04 and my acceleration on the GPU works fine when I connect a monitor and run it locally. It also works fine when I run it remotely so long as a monitor is connected. Once the monitor is disconnected I get self.exec_net =
self.ie.load_network(network=self.net,device_name=self.plugin)
File "ie_api.pyx", line 178, in
openvino.inference_engine.ie_api.IECore.load_network
File "ie_api.pyx", line 187, in
RuntimeError: Failed to create plugin
/opt/intel/openvino_2020.3.194/deployment_tools/inference_engine/lib/intel64/libclDNNPlugin.so
for device GPU
Please, check your environment
[CLDNN ERROR]. clGetPlatformIDs error -1001
Is the GPU being disabled when no monitor is detected? if so, how can I get around this issue?
Hi @Kahren ,
I will close this issue. From the link to your question on StackOverflow I can see it is an xrdp limitation.
