UP Xtreme UEFI BIOS V1.9 and UP Xtreme Windows 10 64-bit drivers not booting
Hi, we have updated the BIOS of the UP Xtreme (i7) to Bios 1.9 (GO_Entire.nsh). We installed Windows 10 IoT LSB with no problems. After the installation we installed Step 1 Chipset drivers installation. Once completed we need to reboot. After the reboot Windows does not boot any more and gives a stop INACCESSIBLE BOOT DEVICE.
So, to be clear. Without the driver updaste windows works, with the driver update windows stops working. How can we solve this?
Hi @allardblom ,
“Windows 10 IOT LSB”
I think that Win10 version is probably too old to install the graphic driver. (version 1607 I guess)
To double-check it, please type in winver on search bar then hit Enter keyPlease make sure they have at least version 1809+ installed
Here's information from our Compatibility Test Report
Here is some additional information found from google
[Fix] This Installation Package Is not Supported by This Processor Type - Driver EasyI think it's a reason why there is the error from installing the graphic driver
Anyhow, I would propose to try upgrading the Win10 version to 1809 and above.
Thanks and regards,
Pratik
