7 inch touch eDP display
I have the UP board with windows is. I followed the directions to hook cables and change bios to eDP for the UP shop 7 inch touch display. The display does not work or even light up upon boot. Any suggestions?
@lunchbox
I suggest you double check your cable connection.
Refer to the steps below for troubleshooting
1. Panel Support from Disabled to “Enable” and setup for “eDP” to Panel Type
2. Check your panel connection. Make sure the cable and touch panel are properly connected
3. It should work as normal, like the picture below
@rogertsai(AAEON) said:
@lunchbox five nights at freddy's
Thanks guys. It was helpful
