Up Squared Intel 2230 Wifi
After installing the Intel WiFi kit (https://up-shop.org/m-2-2230-wifi-kit-wifi-802-11-ac-2t2r-for-up-squared-metal-chassis.html) and installing Ubuntu 20.04 from the instructions https://wiki.up-community.org/Ubuntu_20.04
I'm unable to access the wifi
sudo iwlist wlan0 scan
wlan0 Interface doesn't support scanning
seems like the driver or device is not available? Anyone got this to work?
if during the installation you didn't select the option to install third party firmware, it won't work.
During the OS installation, after the partitioning please select type of installation (full or minimal) and select "install third party firmware..."
@DCleri said:
if during the installation you didn't select the option to install third party firmware, it won't work.During the OS installation, after the partitioning please select type of installation (full or minimal) and select "install third party firmware..."
I did this and I'm having the same problem. Third party firmware checkbox was checked at install, still no wifi adapter detected. Help please
Hi @General_Anubis ,
Can you confirm which ubuntu version and kernel you have?
