UpBridge GPIO pin mappings?
gerfen
gerfen New Member Posts: 31 ✭✭
edited March 2020 in UP Core Windows
Referencing the documentation for the GPIO pin mappings from the UpBridge API to the physical GPIO pins on the 100 pin header:
The mapping shows 22 pins. When I enumerate the DIO pins via the UpBridge.Up like so:
var status = (GpioStatus) upBridge_.GpioGetCaps(0, out uint numberOfGpioPins, out uint disabled);
numberOfGpioPins equals 24. To which physical pins are the the extra 2 DIO pins mapped?
  • gerfen
    I received more information from AAEON tech support. DIO 23 and DIO 24 are used internally and therefore, should **not **be used in code.
