kernel compilation error
New Member Posts: 4
I would like to ask you to solve my problem.
I wanted to compile the ubilinux kernel for using I2S
and the compilation ends with an error. Where can there be a mistake?
Thank you.
appears at the end of the compilation:
dpkg-source: info: use the '3.0 (quilt)' format to have separate and documented changes to upstream files, see dpkg-source (1)
dpkg-source: error: unrepresentable changes to source
dpkg-buildpackage: error: dpkg-source -i.git -b linux has given error exit status 1
scripts / Makefile.package: 73: 'deb-pkg' target failed
make [1]: *** [deb-pkg] Error 1
Makefile: 1426: instructions for the deb-pkg target failed
Welcome!
Welcome!
