Can't install Ubuntu 16.04 on UP board
Alrevan
New Member Posts: 1 ✭
I tried to install ubuntu 16.04 on my board several times.
The installation seems to work fine until when we have to reboot the card and instead of rebooting properly we get a blackscreen with the following kind of logs displaying in loop:
print_req_error: I\O error, dev loop0, sector 35502SQUASHFS error: squashfs_read_data failed to read block 0xad55323
If we restart the card it will not boot on the installation.
We already checked:
- the usb drive used for the installation
- the iso file used
- the disk of the card
Everything seems to be fine there.
Has anyone already encountered this issue ?
What UP Board do you have?
What is the version of the BIOS?
What PSU are you using?
