USB3.0 device is being recognized as a USB2 device
John
New Member Posts: 4 ✭
When I plug a usb 3.0 flash drive or a usb3.0 hub to UP Board through a USB3.0 OTG adapter, it is always recognized as a USB2 device (e.g. when typing lsusb -t, it's always sitting under "Bus 01.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/14p, 480M" instead of "Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/6p, 5000M". I have tried on both 4.4 and 4.2 upboard kernel. (Definitely using upboard kernel by verifying through uname -r).
When I plug these devices onto my PC instead, it looks fine sitting perfectly under "Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/6p, 5000M".
Any suggestion? (or maybe my OTG cable is just rated for USB2 instead even it has the blue colored thing on the plug).
Extra:
I also had no luck with realsene through OTG adapter, but at least other USB storage device and hub still work. (Still waiting for my USB3.0 micro B Male to micro B male cable to arrive).
Extra:
Looks like there still are issues with the USB 3.0 port.
https://up-community.org/forum/public-otheros/290-usb-3-0-otg-not-switching-to-superspeedDavid wrote:Hi there,
i have a Problem with the USB 3.0 Port (i have a 3.0 OTG Cable to provide me with a Type A connector).
For testing, i plugged in an usb hard drive with 3.0 support.
Because i use gentoo, my kernel is hand made. I have support for xHCI compiled in.
When i connect the HDD everything works, but the device only goes up to 480M (high-speed, USB 2.0) and not 5000M (super-speed, USB 3.0). Have i something not compiled into the kernel which is needed? Usually this setup works fine, but i always tried only boards with real USB 3.0 and not OTG.
Here is the output from dmesg:[ 2.954773] ACPI: bus type USB registered [ 2.954853] usbcore: registered new interface driver usbfs [ 2.954881] usbcore: registered new interface driver hub [ 2.954925] usbcore: registered new device driver usb [ 2.963822] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 1 [ 2.965449] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 [ 2.965456] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.965460] usb usb1: Product: xHCI Host Controller [ 2.965464] usb usb1: Manufacturer: Linux 4.4.6-gentoo xhci-hcd [ 2.965467] usb usb1: SerialNumber: 0000:00:14.0 [ 2.965822] hub 1-0:1.0: USB hub found [ 2.966444] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2 [ 2.966957] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003 [ 2.966963] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.966967] usb usb2: Product: xHCI Host Controller [ 2.966971] usb usb2: Manufacturer: Linux 4.4.6-gentoo xhci-hcd [ 2.966975] usb usb2: SerialNumber: 0000:00:14.0 [ 2.967371] hub 2-0:1.0: USB hub found [ 3.318392] usb 1-1: new high-speed USB device number 2 using xhci_hcd [ 3.488082] usb 1-1: New USB device found, idVendor=174c, idProduct=55aa [ 3.488182] usb 1-1: New USB device strings: Mfr=2, Product=3, SerialNumber=1 [ 3.488190] usb 1-1: Product: USB 3.0 device [ 3.488237] usb 1-1: Manufacturer: Intenso [ 3.488242] usb 1-1: SerialNumber: 90900000000000003214
and here is the output of "lsusb -t"up ~ # lsusb -t /: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/6p, 5000M /: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/7p, 480M |__ Port 1: Dev 2, If 0, Class=Mass Storage, Driver=uas, 480M
and here is the verbose output of the device:Bus 001 Device 002: ID 174c:55aa ASMedia Technology Inc. ASM1051 SATA 3Gb/s bridge Device Descriptor: bLength 18 bDescriptorType 1 bcdUSB 2.10 bDeviceClass 0 bDeviceSubClass 0 bDeviceProtocol 0 bMaxPacketSize0 64 idVendor 0x174c ASMedia Technology Inc. idProduct 0x55aa ASM1051 SATA 3Gb/s bridge bcdDevice 1.00 iManufacturer 2 Intenso iProduct 3 USB 3.0 device iSerial 1 90900000000000003214 bNumConfigurations 1 Configuration Descriptor: bLength 9 bDescriptorType 2 wTotalLength 85 bNumInterfaces 1 bConfigurationValue 1 iConfiguration 0 bmAttributes 0xc0 Self Powered MaxPower 0mA Interface Descriptor: bLength 9 bDescriptorType 4 bInterfaceNumber 0 bAlternateSetting 0 bNumEndpoints 2 bInterfaceClass 8 Mass Storage bInterfaceSubClass 6 SCSI bInterfaceProtocol 80 Bulk-Only iInterface 0 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x81 EP 1 IN bmAttributes 2 Transfer Type Bulk Synch Type None Usage Type Data wMaxPacketSize 0x0200 1x 512 bytes bInterval 0 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x02 EP 2 OUT bmAttributes 2 Transfer Type Bulk Synch Type None Usage Type Data wMaxPacketSize 0x0200 1x 512 bytes bInterval 0 Interface Descriptor: bLength 9 bDescriptorType 4 bInterfaceNumber 0 bAlternateSetting 1 bNumEndpoints 4 bInterfaceClass 8 Mass Storage bInterfaceSubClass 6 SCSI bInterfaceProtocol 98 iInterface 0 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x81 EP 1 IN bmAttributes 2 Transfer Type Bulk Synch Type None Usage Type Data wMaxPacketSize 0x0200 1x 512 bytes bInterval 0 Data-in pipe (0x03) Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x02 EP 2 OUT bmAttributes 2 Transfer Type Bulk Synch Type None Usage Type Data wMaxPacketSize 0x0200 1x 512 bytes bInterval 0 Data-out pipe (0x04) Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x83 EP 3 IN bmAttributes 2 Transfer Type Bulk Synch Type None Usage Type Data wMaxPacketSize 0x0200 1x 512 bytes bInterval 0 Status pipe (0x02) Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x04 EP 4 OUT bmAttributes 2 Transfer Type Bulk Synch Type None Usage Type Data wMaxPacketSize 0x0200 1x 512 bytes bInterval 0 Command pipe (0x01) Binary Object Store Descriptor: bLength 5 bDescriptorType 15 wTotalLength 22 bNumDeviceCaps 2 USB 2.0 Extension Device Capability: bLength 7 bDescriptorType 16 bDevCapabilityType 2 bmAttributes 0x0000f41e BESL Link Power Management (LPM) Supported BESL value 1024 us Deep BESL value 61440 us SuperSpeed USB Device Capability: bLength 10 bDescriptorType 16 bDevCapabilityType 3 bmAttributes 0x00 wSpeedsSupported 0x000e Device can operate at Full Speed (12Mbps) Device can operate at High Speed (480Mbps) Device can operate at SuperSpeed (5Gbps) bFunctionalitySupport 1 Lowest fully-functional device speed is Full Speed (12Mbps) bU1DevExitLat 10 micro seconds bU2DevExitLat 2047 micro seconds can't get debug descriptor: Resource temporarily unavailable Device Status: 0x0001 Self Powered
as you can see, the device really supports super-speed
(Device can operate at SuperSpeed (5Gbps))
Any advice?
- 63 Announcements & News
- 104 Welcome Developers!
- 22 Tech Updates
- 3.5K UP Products
- 24 UP 7000
- 11 UP Xtreme i12
- 15 UP Squared Pro 7000
- 23 UP Squared V2
- 67 UP 4000
- 58 UP Squared Pro
- 144 UP Xtreme
- 820 UP Squared
- 75 UP Core Plus
- 223 UP Core
- 40 UP AI Edge
