how to understand the 40HAT pin mapping configuration
It's so confusing,
I was trying to set a gpio pin to output high through c++ code using the mraa library. and I had so much trouble finding the right pin number to use to set the good pin.
the pin number has 2 gpio number asssociated.
in my BIOS, the pin is GPIO15 (pin 37)
and setting it to output high really worked. but with the mraa library I had to do
mraa::Gpio gpio_1(26, true, true); gpio_1.dir(mraa::DIR_OUT); gpio_1.write(1);
for make it working.
maybe the third argument to gpio at true makes the numbering different, but puting false did that no pins where accepted so I had no choice.
In the document of my up4000:
the pin is numbered like in the BIOS, while the wiki schema:
uses the gpio26 number instead, the only constant being the pin number 37.
so I want to set the GPIO19 (pin 16)
in my BIOS to output because my SPI_CLK isn't working if I don't do that. will this work if I use mraa with gpio23 instead because the wiki says so.
why is this so confusing. This other wiki page: https://github.com/up-board/up-community/wiki/Pinout even has different numbering
Hi Sir
Please take this figure as the main.
Harry Chiu
- 63 Announcements & News
- 88 Product News - New Product/Product Change Notice/ End-of-life
- 104 Welcome Developers!
- 22 Tech Updates
- 3.5K UP Products
- 27 UP 7000
- 11 UP Xtreme i12
- 15 UP Squared Pro 7000
- 23 UP Squared V2
- 68 UP 4000
- 58 UP Squared Pro
- 144 UP Xtreme
- 820 UP Squared
- 75 UP Core Plus
- 223 UP Core
- 40 UP AI Edge
