How can I get the capacitors inside of UpSquared?
Hi all,
I need to use the capacitor data used inside UpSquared to be able to make some calculations about power issues? How can I reach capacitor data inside?
  • Aling
    @yunus_acz Not sure what power issue you try to solve, maybe you can elaborate more. There are many different capacitors in UP Squared, we will not be able to provide the information.
  • yunus_acz
    yunus_acz New Member Posts: 17
    edited March 2020
    @Aling Hi! I need to learn that when I power-off UpSquared how many miliseconds it continue to work. I need to learn this time, thats why I need capacitor values. If you can give me the time, no need to learn capacitors. I mean just cutting of the power cable so power supply capacitors not important.
  • krishnaorakkan
    krishnaorakkan New Member Posts: 8
    Hi @yunus_acz ,
    I hope you have gotten your answer from @rogertsai(AAEON) in the other post that you had asked. Please refer to " https://forum.up-community.org/discussion/comment/11007#Comment_11007 " for further clarification.
  • uscdadnyc
    uscdadnyc New Member Posts: 34 ✭✭
    Capacitors inside the Up Squared? I have not looked or played w/ the UP Square. But if the UP Squared is anything like the Up Board IDK (I Don't Think) there are any Capacitors (Electrolytic?) on the Up Squared that can conceivably hold a Charge once the Power Brick Connection is Removed. I could be Wrong. Good Luck.
