Ethernet Adapter not detected with UP Core Plus with UP Vision Plus X attached
klichko
klichko New Member Posts: 1
edited February 2020 in UP Core Plus Carrier boards
I've been trying to set up UP Core Plus extended with UP Vision Plus X with Ubuntu 18.04 by following the instructions from https://wiki.up-community.org/Ubuntu#Ubuntu_18.04_installation_and_configuration
After completing all the steps from the guide Ethernet adapter from Vision Plus X is not detected, the output from ifconfig gives the following
upcore@upcore-UPC-PLUS:~$ ifconfig
lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
        inet 127.0.0.1  netmask 255.0.0.0
        loop  txqueuelen 1000  (Local Loopback)
        RX packets 597  bytes 61040 (61.0 KB)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 597  bytes 61040 (61.0 KB)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
wlan0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 192.168.0.104  netmask 255.255.255.0  broadcast 192.168.0.255
        inet6 fe80::579b:3cdc:817a:409e  prefixlen 64  scopeid 0x20<link>
        ether 10:d0:7a:15:3c:68  txqueuelen 1000  (Ethernet)
        RX packets 4281  bytes 2679864 (2.6 MB)
        TX packets 4391  bytes 775471 (775.4 KB)
lshw:
upcore@upcore-UPC-PLUS:~$ sudo lshw |grep -A 6 network
*-network
description: Wireless interface
physical id: 1
logical name: wlan0
serial: 10:d0:7a:15:3c:68
capabilities: ethernet physical wireless
configuration: broadcast=yes driver=brcmfmac driverversion=7.45.18 firmware=01-6a2c8ad4 ip=192.168.0.104 multicast=yes wireless=IEEE 802.11
lspci:
upcore@upcore-UPC-PLUS:~$ sudo lspci
00:00.0 Host bridge: Intel Corporation Celeron N3350/Pentium N4200/Atom E3900 Series Host Bridge (rev 0b)
00:02.0 VGA compatible controller: Intel Corporation Device 5a85 (rev 0b)
00:0e.0 Multimedia audio controller: Intel Corporation Celeron N3350/Pentium N4200/Atom E3900 Series Audio Cluster (rev 0b)
00:0f.0 Communication controller: Intel Corporation Celeron N3350/Pentium N4200/Atom E3900 Series Trusted Execution Engine (rev 0b)
00:11.0 Unclassified device [0050]: Intel Corporation Celeron N3350/Pentium N4200/Atom E3900 Series Integrated Sensor Hub (rev 0b)
00:12.0 SATA controller: Intel Corporation Celeron N3350/Pentium N4200/Atom E3900 Series SATA AHCI Controller (rev 0b)
00:13.0 PCI bridge: Intel Corporation Celeron N3350/Pentium N4200/Atom E3900 Series PCI Express Port A #1 (rev fb)
00:13.1 PCI bridge: Intel Corporation Celeron N3350/Pentium N4200/Atom E3900 Series PCI Express Port A #2 (rev fb)
00:13.2 PCI bridge: Intel Corporation Celeron N3350/Pentium N4200/Atom E3900 Series PCI Express Port A #3 (rev fb)
00:13.3 PCI bridge: Intel Corporation Celeron N3350/Pentium N4200/Atom E3900 Series PCI Express Port A #4 (rev fb)
00:14.0 PCI bridge: Intel Corporation Celeron N3350/Pentium N4200/Atom E3900 Series PCI Express Port B #1 (rev fb)
00:14.1 PCI bridge: Intel Corporation Celeron N3350/Pentium N4200/Atom E3900 Series PCI Express Port B #2 (rev fb)
00:15.0 USB controller: Intel Corporation Celeron N3350/Pentium N4200/Atom E3900 Series USB xHCI (rev 0b)
00:15.1 USB controller: Intel Corporation Device 5aaa (rev 0b)
00:16.0 Signal processing controller: Intel Corporation Celeron N3350/Pentium N4200/Atom E3900 Series I2C Controller #1 (rev 0b)
00:16.1 Signal processing controller: Intel Corporation Celeron N3350/Pentium N4200/Atom E3900 Series I2C Controller #2 (rev 0b)
00:17.0 Signal processing controller: Intel Corporation Celeron N3350/Pentium N4200/Atom E3900 Series I2C Controller #5 (rev 0b)
00:17.2 Signal processing controller: Intel Corporation Celeron N3350/Pentium N4200/Atom E3900 Series I2C Controller #7 (rev 0b)
00:17.3 Signal processing controller: Intel Corporation Celeron N3350/Pentium N4200/Atom E3900 Series I2C Controller #8 (rev 0b)
00:18.0 Signal processing controller: Intel Corporation Celeron N3350/Pentium N4200/Atom E3900 Series HSUART Controller #1 (rev 0b)
00:18.1 Signal processing controller: Intel Corporation Celeron N3350/Pentium N4200/Atom E3900 Series HSUART Controller #2 (rev 0b)
00:18.2 Signal processing controller: Intel Corporation Celeron N3350/Pentium N4200/Atom E3900 Series HSUART Controller #3 (rev 0b)
00:19.0 Signal processing controller: Intel Corporation Celeron N3350/Pentium N4200/Atom E3900 Series SPI Controller #1 (rev 0b)
00:1a.0 Serial bus controller [0c80]: Intel Corporation Celeron N3350/Pentium N4200/Atom E3900 Series PWM Pin Controller (rev 0b)
00:1b.0 SD Host controller: Intel Corporation Celeron N3350/Pentium N4200/Atom E3900 Series SDXC/MMC Host Controller (rev 0b)
00:1c.0 SD Host controller: Intel Corporation Celeron N3350/Pentium N4200/Atom E3900 Series eMMC Controller (rev 0b)
00:1e.0 SD Host controller: Intel Corporation Celeron N3350/Pentium N4200/Atom E3900 Series SDIO Controller (rev 0b)
00:1f.0 ISA bridge: Intel Corporation Celeron N3350/Pentium N4200/Atom E3900 Series Low Pin Count Interface (rev 0b)
00:1f.1 SMBus: Intel Corporation Celeron N3350/Pentium N4200/Atom E3900 Series SMBus Controller (rev 0b)
However, dmidecode seems to be able to detect ethernet adapter
upcore@upcore-UPC-PLUS:~$ sudo dmidecode -t baseboard
# dmidecode 3.1
Getting SMBIOS data from sysfs.
SMBIOS 3.0.0 present.
Handle 0x0002, DMI type 2, 15 bytes
Base Board Information
    Manufacturer: AAEON
    Product Name: UPC-PLUS
    Version: V0.1
    Serial Number: Default string
    Asset Tag: Default string
    Features:
        Board is a hosting board
        Board is replaceable
    Location In Chassis: Default string
    Chassis Handle: 0x0003
    Type: Motherboard
    Contained Object Handles: 0
Handle 0x0025, DMI type 10, 6 bytes
On Board Device Information
    Type: Video
    Status: Enabled
    Description:    To Be Filled By O.E.M.
Handle 0x002D, DMI type 41, 11 bytes
Onboard Device
    Reference Designation:  Onboard IGD
    Type: Video
    Status: Enabled
    Type Instance: 1
    Bus Address: 0000:00:02.0
Handle 0x002E, DMI type 41, 11 bytes
Onboard Device
    Reference Designation:  Onboard LAN
    Type: Ethernet
    Status: Enabled
    Type Instance: 1
    Bus Address: 0000:00:19.0
Handle 0x002F, DMI type 41, 11 bytes
Onboard Device
    Reference Designation:  Onboard 1394
    Type: Other
    Status: Enabled
    Type Instance: 1
    Bus Address: 0000:03:1c.2
I've tried to manually install driver for Realtek 8111G driver (since that is the one it seems to be the right one according to https://up-board.org/ai-edge/vision-plus-x) with:
sudo apt-get install r8168-dkms
...but still nothing
Also, when plugging live LAN cable LED diodes on the ethernet port on the Vision Plus X light up, so it seems that it is alive to some extent, but still I'm not sure if this is hardware issue or not. The USB ports on Vision Plus X are working without any issue, and Myriad chips can be detected and used, although not without issues, but that is the topic for another discussion :)
Has anybody encountered this issue with the UP Core Plus and Vision Plus X, any idea what can be done to make it work?
Damir
EDIT: Sorry for the formatting, I've put all the console commands/output under code, not sure why it didn't work for all the sections
