MCP2515 with kernel 4.16
QiayuanLiao
QiayuanLiao New Member Posts: 7 ✭
I have used a standard 4.4 kernel with UP Board HAT support patch and an RT patch Ubuntu-RT-UP-Board. I am trying to use mcp2515 for CAN Bus, I write a driver which work well.
#include <linux/init.h>
#include <linux/module.h>
#include <linux/spi/spi.h>
#include <linux/can/platform/mcp251x.h>
#include <linux/gpio.h>
#include <linux/interrupt.h>
int busnum = 2;
int chip_select = 0;
int gpio_int = 25;
module_param(busnum, int, S_IRUSR | S_IWUSR | S_IRGRP | S_IROTH);
MODULE_PARM_DESC(busnum, "busnum of spi bus to use");
module_param(gpio_int, int, S_IRUSR | S_IWUSR | S_IRGRP | S_IROTH);
MODULE_PARM_DESC(gpio_int, "linux gpio number of INT gpio");
module_param(chip_select, int, S_IRUSR | S_IWUSR | S_IRGRP | S_IROTH);
MODULE_PARM_DESC(chip_select, "spi chip select");
int gpio_requested = 0;
struct spi_device * dev1;
static struct mcp251x_platform_data mcp251x_info = {
  .oscillator_frequency = 16000000,
static struct spi_board_info spi_device_info = {
  .modalias = "mcp2515",
  .platform_data = & mcp251x_info,
  .irq = -1,
  .max_speed_hz = 10 * 1000 * 1000,
static int __init mcp2515_init(void) {
  int ret;
  struct spi_master * master;
  printk("mcp2515: init\n");
  ret = gpio_request(gpio_int, "sysfs");
  if (ret) {
    printk("mcp2515: could not request gpio %d\n", gpio_int);
    gpio_free(gpio_int);
    return ret;
  gpio_requested = 1;
  gpio_direction_input(gpio_int);
  ret = gpio_to_irq(gpio_int);
  printk("mcp2515: irq for pin %d is %d\n", gpio_int, ret);
  spi_device_info.irq = ret;
  spi_device_info.bus_num = busnum;
  spi_device_info.chip_select = chip_select;
  master = spi_busnum_to_master(spi_device_info.bus_num);
  if (!master) {
    printk("mcp2515: MASTER not found.\n");
    ret = -ENODEV;
    goto error_postgpio;
  // create a new slave device, given the master and device info
  dev1 = spi_new_device(master, & spi_device_info);
  if (!dev1) {
    printk("mcp2515: FAILED to create slave.\n");
    ret = -ENODEV;
  printk("mcp2515: device created!\n");
  return 0;
  error_postgpio:
  return ret;
static void __exit mcp2515_exit(void) {
  printk("mcp2515: exit\n");
  if (dev1) {
    spi_unregister_device(dev1);
  if (gpio_requested)
module_init(mcp2515_init);
module_exit(mcp2515_exit);
MODULE_LICENSE("GPL");
MODULE_AUTHOR("One");
MODULE_DESCRIPTION("MCP2515");
But I want to use UP Squared, and I try the kernel 4.15/4.16 with the driver I write on UP Board, but when I load the MCP2515 withsudo modprobe mcp2515 and sudo ip link set can0 type can bitrate 1000000 everything since ok. But when I type sudo ip link set up can0 and enter, the whole system crash. I got (sorry for the camera view, the system is crash):
So anybody has a similar work and suggestion?
