How to flash the UP Xtreme with Dediprog flash programmer
I have a cable that fits on the 12 pin header on the UP Xtreme (header between the HDMI Connector and the CMOS Battery header) and connects to a Dediprog flash programmer. This cable works with a Dediprog and the UP Squared board (capable of flashing the BIOS on the board) but on the UP Xtreme the Dediprog does not detect the flash part. Are there any differences in the pin out? What is the flash manufacturer and part number on the UP Xtreme?
Once Update to Dediprog software is updated to 6.5.0.21 and the 12 pin connecter is connected on the UP Xtreme, the Dediprog software detects the UP Xtreme to be a Windbond Part # W25Q256JW. Size 32768 KB 1.8V.
The pin out on the UP Xtreme is the same as on the 12 pin head connecter on the UP Squared -
Hi @Laurie
It is good that you were able to solve the issue and it was just a missing SW update for Dediprog.
Thanks for reporting the solution.
- Hi @Laurie , where did you get a Dediprog cable that works with the Up Xtreme? -Mike
