Up Core Plus and UP Vision Plus X software configuration issue
Hello.
I've bought Up Core Plus and Up Vision Plus X board with 3 intel Myriad X VPUs.
https://up-shop.org/featured/265-up-vision-plus-x.html
I've assembled them together and installed Ubuntu 18.04 and OpenVINO 2019R1.1, which works fine on CPU.
But when I try to run it with -d MYRIAD flag it fails with errors like can not find device, same thing for -d HDDL. I have followed all Linux installation guide steps and tried security_camera_bla_bla demo from OpenVINO demo directory.
Can you please provide proven step by step instruction for preparing and running Intel OpenVINO samples with all three embedded VPUs.
I have already run OpenVINO asynchronous yolo detection on Windows with IEI Acceleration board Mustang and 4 NCUs 2 under Windows 10 on my desktop PC using tiny-yolo model and 4 network instances per VPU.
It seems that my assembly works fine with NCS2, but it still reports some errors even it executed successfully.
Best regards
Aleksandr.
More details here:
At /opt/intel/openvino/deployment_tools/demo, I run
./demo_security_barrier_camera.sh -d MYRIAD
… some scripted preparations …Application start:
Run Inference Engine security_barrier_camera demo
Run ./security_barrier_camera_demo -d MYRIAD -d_va MYRIAD -d_lpr MYRIAD -i /opt/intel/openvino_2019.1.144/deployment_tools/demo/car_1.bmp -m /home/sasha/openvino_models/ir/FP16/Security/object_detection/barrier/0106/dldt/vehicle-license-plate-detection-barrier-0106-fp16.xml -m_va /home/sasha/openvino_models/ir/FP16/Security/object_attributes/vehicle/resnet10_update_1/dldt/vehicle-attributes-recognition-barrier-0039-fp16.xml -m_lpr /home/sasha/openvino_models/ir/FP16/Security/optical_character_recognition/license_plate/dldt/license-plate-recognition-barrier-0001-fp16.xml
[ INFO ] InferenceEngine:
API version ............ 1.6
Build .................. custom_releases/2019/R1.1_28dfbfdd28954c4dfd2f94403dd8dfc1f411038b
[ INFO ] Capturing video streams from the video files or loading images
[ INFO ] Files were added: 1
[ INFO ] /opt/intel/openvino_2019.1.144/deployment_tools/demo/car_1.bmp
[ INFO ] Number of input image files: 1
[ INFO ] Number of input video files: 0
[ INFO ] Number of input channels: 1
[ INFO ] Display resolution: 1920x1080
[ INFO ] Loading plugin MYRIADAPI version ............ 1.6 Build .................. 23780 Description ....... myriadPlugin
[ INFO ] Loading network files for VehicleDetection
[ INFO ] Batch size is forced to 1
[ INFO ] Checking Vehicle Detection inputs
[ INFO ] Checking Vehicle Detection outputs
[ INFO ] Loading Vehicle Detection model to the MYRIAD plugin
E: [ncAPI] [ 293174] ncDeviceOpen:800 Failed connection to device (1.5.1-ma2480) with error 5
[ ERROR ] Can not init USB device: NC_DEVICE_NOT_FOUND
Error on or near line 228; exiting with status 1Then I inserted NCS2 and run the same script:
[ INFO ] Loading network files for VehicleAttribs
[ INFO ] Batch size is forced to 1 for Vehicle Attribs
[ INFO ] Checking VehicleAttribs inputs
[ INFO ] Checking Vehicle Attribs outputs
[ INFO ] Loading Vehicle Attribs model to the MYRIAD plugin
E: [ncAPI] [ 624758] ncDeviceOpen:672 Failed to find suitable device, rc: X_LINK_DEVICE_NOT_FOUND
[ INFO ] Loading network files for Licence Plate Recognition (LPR)
[ INFO ] Batch size is forced to 1 for LPR Network
[ INFO ] Checking LPR Network inputs
[ INFO ] Checking LPR Network outputs
[ INFO ] Loading LPR model to the MYRIAD plugin
E: [ncAPI] [ 626812] ncDeviceOpen:672 Failed to find suitable device, rc: X_LINK_DEVICE_NOT_FOUND
[ INFO ] Start inference
To close the application, press 'CTRL+C' or any key with focus on the output windowAverage inference time: 48.7759 ms (20.5019 fps)
Average vehicle detection time: 31.711 ms (31.5348 fps)
Average vehicle attribs time: 5.1753 ms (193.226 fps)
Average lpr time: 11.0977 ms (90.1085 fps)
Total execution time: 3434.22
[ INFO ] Execution successful
Demo completed successfully.
Finally, in order to compare and be sure that NCS2 actually did the things, the same script started without -d MYRIAD option (on Intel CPU) and it shows the following performance:
Average inference time: 48.098 ms (20.7909 fps)
Average vehicle detection time: 21.1481 ms (47.2857 fps)
Average vehicle attribs time: 9.6757 ms (103.352 fps)
Average lpr time: 22.2226 ms (44.9993 fps)
Total execution time: 4611.07
Despite the strange similarity of Average inference time, average times of inference stages look really accelerated by NCS2. But it still does not help with embedded VPUs.
Additional information about USB devices list.
It looks like 03e7:2485 is my Myriad X, but I can see only one device instead of three ones.
The output of lsusb:Bus 002 Device 002: ID 0951:1666 Kingston Technology DataTraveler G4 Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub Bus 001 Device 005: ID 2c42:5114 Bus 001 Device 004: ID 0458:6001 KYE Systems Corp. (Mouse Systems) GF3000F Ethernet Adapter Bus 001 Device 003: ID 03e7:2485 Bus 001 Device 002: ID 05e3:0610 Genesys Logic, Inc. 4-port hub Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Output of lsusb -v -d 03e7:2485
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 0 (Defined at Interface level)
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
idVendor 0x03e7
idProduct 0x2485
bcdDevice 0.01
iManufacturer 1 Movidius Ltd.
iProduct 2 Movidius MyriadX
iSerial 3 03e72485
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 32
bNumInterfaces 1
bConfigurationValue 1
iConfiguration 0
bmAttributes 0x80
(Bus Powered)
MaxPower 500mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 2
bInterfaceClass 255 Vendor Specific Class
bInterfaceSubClass 17
bInterfaceProtocol 255
iInterface 0
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
wMaxPacketSize 0x0200 1x 512 bytes
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x01 EP 1 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
Device Qualifier (for other device speed):
bLength 10
bDescriptorType 6
bcdUSB 2.00
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
Device Status: 0x0000
(Bus Powered) -
In order to compare the situation with NCS2, I have plugged it in and requested lsusb twice again
As we can see, their descriptors are the same and moreover, they share the same Bus. It is still interesting, why I can see only one embedded device on the USB bus. This issue could be addressed to the hardware developers: which bus initially is used by 3 Myriad X devices? It would be great if they share structural schematics or post some kind of clarification. Thanks.Output of lsusb, when additionally NCS2 plugged in:
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub Bus 001 Device 005: ID 2c42:5114 Bus 001 Device 004: ID 0458:6001 KYE Systems Corp. (Mouse Systems) GF3000F Ethernet Adapter Bus 001 Device 006: ID 03e7:2485 Bus 001 Device 003: ID 03e7:2485 Bus 001 Device 002: ID 05e3:0610 Genesys Logic, Inc. 4-port hub Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Finally, the output of lsusb -v -d 03e7:2485 when NCS2 inserted.
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
idVendor 0x03e7
idProduct 0x2485
bcdDevice 0.01
iSerial 3 03e72485
bLength 9
bDescriptorType 2
wTotalLength 32
bNumInterfaces 1
iConfiguration 0
bmAttributes 0x80
(Bus Powered)
MaxPower 500mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 2
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 7
bDescriptorType 5
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 10
bDescriptorType 6
bcdUSB 2.00
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
(Bus Powered)Bus 001 Device 003: ID 03e7:2485
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
idVendor 0x03e7
idProduct 0x2485
bcdDevice 0.01
iSerial 3 03e72485
bLength 9
bDescriptorType 2
wTotalLength 32
bNumInterfaces 1
iConfiguration 0
bmAttributes 0x80
(Bus Powered)
MaxPower 500mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 2
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 7
bDescriptorType 5
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 10
bDescriptorType 6
bcdUSB 2.00
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
(Bus Powered) -
I have some news.
We accidentally purchased 2 sets (UCP+Up Vision X), and one of them was marked as "Engineering Sample".
The second one without any marks has enhanced heatsink (it has a notch for RTC-header removing).The first finding has been made in lsusb answer:
Bus 002 Device 002: ID 05e3:0620 Genesys Logic, Inc. Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub Bus 001 Device 005: ID 2c42:5114 Bus 001 Device 004: ID 0458:6001 KYE Systems Corp. (Mouse Systems) GF3000F Ethernet Adapter Bus 001 Device 003: ID 03e7:2485 Bus 001 Device 002: ID 05e3:0610 Genesys Logic, Inc. 4-port hub Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub Bus 003 Device 003: ID 03e7:2485 Bus 003 Device 002: ID 03e7:2485 Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
As we can see, there are 3 Myriads, listed by lsusb in this set.
The previous one returned only one Myriad with 2485 PID. -
For those who googled to here.
The root cause of all issues mentioned above was this blue label on my Up Core Plus board:
