Boot Loop Issue on UPX-MTL155H-A10-3200 When Powered by 24VDC
Hello, I am using the UPX-MTL155H-A10-3200 computer running Ubuntu. I am experiencing the following issue:
When I supply 24VDC – 14A power to the system, the computer shows the UP logo, then the screen turns black, and the UP logo appears again. Sometimes the logo appears five times before the system can finally boot into Ubuntu.
However, in some cases, after showing the UP logo repeatedly, the computer enters the GRUB screen. After the countdown finishes, or even if I press Enter to select Ubuntu, it shows the UP logo again and returns to the GRUB screen. Eventually, the system cannot boot into Ubuntu.
Please advise me on how to resolve this issue. Thank you very much.
Hi @dattqbk
I'm not sure if there's a problem with your hard drive.
Could you try replacing the hard drive??
Harry Chiu
