What should I know about power requirements for UP Boards?
UP Boards typically require a 5V or 12V power supply, depending on the model. However, some of our products require 19V power supply (UP Xtreme, UP Xtreme i12, UP Xtreme i14 and UP Element). It’s crucial to use a power supply that meets the specified voltage and current requirements to ensure stability and avoid damaging the board. Detailed power requirements for each model are available in the product datasheet which you can also download from here: https://downloads.up-community.org/
Welcome!
