Which operating systems are supported by UP Boards, and how do I set them up?
DeliaSirghie
DeliaSirghie Administrator, AAEON Posts: 26 admin
UP Boards support a variety of operating systems, including popular options like Ubuntu, Windows 10, and Yocto. Additionally, certain models also support specialized systems like ubilinux (a Debian-based distribution), and other custom Linux distributions optimized for industrial and embedded applications.
To set up an operating system on your UP Board, follow these general steps:
  1. Download the OS Image:
You can find OS images and installation guides on the official UP Community GitHub page: https://github.com/up-board/up-community/wiki/Setup
Each OS has its own dedicated section with detailed instructions.
  1. Create a Bootable USB Drive:
Use tools like Rufus (for Windows) or Etcher (for Linux/Mac) to create a bootable USB drive with the downloaded OS image.
  1. Install the OS:
Insert the bootable USB drive into your UP Board and power it on. Access the BIOS by pressing the appropriate key during boot (typically ESC or F7). From the BIOS menu, set the USB drive as the primary boot device.
Follow the on-screen instructions to complete the OS installation.
  1. Post-Installation Setup:
After installation, you may need to install additional drivers or packages depending on the OS. For example, on Ubuntu, you might need to add repositories or install specific packages to fully utilize the hardware capabilities of the UP Board.
For more detailed instructions on setting up each supported operating system, refer to the Setup Guide on GitHub: https://github.com/up-board/up-community/wiki/Setup
This guide provides step-by-step instructions and troubleshooting tips to help you get your UP Board up and running smoothly with your chosen OS.
