AI Core + Net Plus + Core Plus Combination
elforce001
elforce001 New Member Posts: 1 ✭
Greetings,
I want to know if it's possible to combine these boards together. I know I can combine the Core Plus + Net Plus boards but I don't know If I can put the AI Core in the Net Plus mPCIe slot. The reason for this is that I want to be able to use tensorflow (CNN) and also be able to connect any IP related product.
If that's possible, which enclosures, power adapters, etc..., do I need to buy?
Thanks in advance for the help.
  • Aling
    The combination will be like the following:
    UP CORE PLUS+ NETPlus+AI Core==> No problem.
    UP Core Plus+ AI Plus+AI Core==> No problem
    UP Core Plus +AI Plus+ NetPLus==>NG, it doesn't work.
    You will need to buy a 12V power adapter, which we will sell at UP shop later one.
    For the enclosure, we will also introduce in UP shop.
    The soonest way to get it is to join Kickstarter campaign which we will launch in the end of May.
