Realsense D415 and UP board compatibility issue, USB ports
I am using the UP board 4GB ram/ 32GB storage, part # RE-UP-CHT01-A12-0432.
Previously I used it with the Realsense R200, as part of the realsense developer kit, found here: https://click.intel.com/intelr-realsensetm-robotic-development-kit-2461.html
I have acquired some of the new Realsense cameras, the D415, and am trying to integrate it with the UP board and my computer vision software. I can't use the cable supplied with the D415, because it is USB type C to type A, and the type A ports on the UP board are USB 2.0, not 3.0 as the D415 requires.
I have also tried this cable:
https://www.amazon.com/gp/product/B012V56992/ref=oh_aui_detailpage_o07_s00?ie=UTF8&psc=1
I can get the UP board to recognize the D415 using this cable, but it is listed as a USB 2.0 device, even though it is plugged into the USB 3.0 Micro B port.
If anyone could please assist me on what could be the issue I would really appreciate it.
Thank you!
Same problem here. Only 640x480 30fps max
You can use this adapter to fit the camera on UP Board Micro USB3.0: https://up-shop.org/home/91-usb30-adapter-micro-b-male-to-a-female.html
Then connect the camera and after booting the system, the D415 should be detected as USB3.0 device.
