ABS Case is not designed for SATA drive or HAT expabnsion
Edgett
Edgett New Member Posts: 7
I received my ABS case with my Pentium 8GB/128GB Up2 today.
The case is not well thought out.
A 2.5" SATA drive doesn't fit inside.
  • Aling
    As explained in the previous posts, UP Squared metal or plastic chassis are not designed for any SATA drive or HAT expansion.
    We will need to fulfill MOQ of current compact version first, then we can negotiate with our suppliers to produce more version for us.
  • Edgett
    Do you have an ETA on when minimum order quantity will be fulfilled?
  • Aling
    So far we don't see the demand on ABS chassis for HAT expansion, however, we are checking the possibility to implement in the metal chassis. We are not finalize yet, if we decide to do , it will be available in 3-4 months.
