Trouble booting Ubuntu from USB drive with a working Ubilinux system.
Mark Curry
Mark Curry New Member Posts: 8 ✭
I installed Ubilinux on the UP board just fine using a USB stick, just fine, no problems. Been using it for a couple months or more. Now when I want to install Ubuntu (full installation) so I can run ROS, I cannot get the system to boot from the USB. Ubilinux just boots normally. I've tried several USB drives, no luck. I tried Rufus and win32diskimager to burn the image, still no luck. I'm sure I'm just missing something simple here... anyone got a clue for me. thanks
  • Mark Curry
    Doh!, I just needed to remove Ubilinux from the boot sequence. Yeah, it was that simple.
  • Dan O'Donovan
    In case its useful in the future, please note that you can press F7 when the BIOS is loading (typically just after the Num-Lock LED is turned on) and you should get a menu to pick alternative disk partitions to boot from.
  • Mark Curry
    Good to know.
    I actually installed Ubuntu alongside Ubilinux, all seems good now.
    thanks much
