How to make running leds with Windows 10 IoT uwp c#
Ken Ekholm
Ken Ekholm New Member Posts: 1 ✭
I have problem to create running leds with Raspberry PI 3 Windows IOT, but random led blink does work.
The code for both are almost the same, only diffrent runnings leds is controlled by variable count and random led
is generated with random generator.
The running led code is below this text. I will get only the first led to light, and rest of leds stays dark. Can someone see what's wrong with this code?
But the random blink led works, which comes after this running leds code and both codes almost identically, but still the running leds code does not work.
Running leds code
private void Timer_Tick(object sender, object e)
            int ledCheck = 1, ledCheck2 = 1;
            int ledValue = 0, ledValue2 = 0;
                //ledValue2 = 1;
            int checkValue = 0;
                    if (ledCheck2 == 1)
                        pinValue1 = GpioPinValue.Low;
                        pin.Write(pinValue1);
                        pinValue2 = GpioPinValue.Low;
                        pin2.Write(pinValue2);
                        pinValue3 = GpioPinValue.Low;
                        pin3.Write(pinValue3);
                        pinValue4 = GpioPinValue.Low;
                        pin4.Write(pinValue4);
                        pinValue5 = GpioPinValue.Low;
                        pin5.Write(pinValue5);
                        pinValue6 = GpioPinValue.Low;
                        pin6.Write(pinValue6);
                        pinValue7 = GpioPinValue.Low;
                        pin7.Write(pinValue7);
                        ledCheck2 = 0;
                   ledValue2 = ledValue2 + 1;
                    TextBlock1.Text = ledValue2.ToString();
                    if (ledValue2 == 1)
                        pinValue1 = GpioPinValue.High;
                    if (ledValue2 == 2)
                        pinValue2 = GpioPinValue.High;
                    if (ledValue == 3)
                        pinValue3 = GpioPinValue.High;
                    if (ledValue2 == 4)
                        pinValue4 = GpioPinValue.High;
                    if (ledValue2 == 5)
                        pinValue5 = GpioPinValue.High;
                    if (ledValue2 == 6)
                        pinValue6 = GpioPinValue.High;
                    if (ledValue2 == 7)
                        pinValue7 = GpioPinValue.High;
                    if (pinValue1 == GpioPinValue.High)
                    if (pinValue2 == GpioPinValue.High)
                    if (pinValue3 == GpioPinValue.High)
                    if (pinValue4 == GpioPinValue.High)
                    if (pinValue5 == GpioPinValue.High)
                    if (pinValue6 == GpioPinValue.High)
                    if (pinValue7 == GpioPinValue.High)
                    TextBlock1.Text = "TEST " + ledValue2.ToString();
Random blink led
                //ledValue2 = 1;
            int checkValue = 0;
                    if (ledCheck == 1)
                        ledCheck = 0;
                    Random rnd = new Random();
                    ledValue = rnd.Next(1, 8);
                    if (ledValue != checkValue)
                        checkValue = ledValue;
                        if (ledValue == 1)
                        if (ledValue == 2)
                       if (ledValue == 3)
                        if (ledValue == 4)
                        if (ledValue == 5)
                        if (ledValue == 6)
                        if (ledValue == 7)
                        TextBlock1.Text = "NOT Same value!";
                    else
                        TextBlock1.Text = "Same value!";
