Installing Vortexbox on the UpBoard -=- Help please.
C Cooper
New Member Posts: 5 ✭
I just received my UpBoard (2Gb/32eMMC).
I was hoping to be able to run the VortexBox Software and OS on the board (vortexbox.org), but I have been having absolutely no luck getting it to boot from either CD or USB into the installer.
I tried the Bootable USB on another PC and it works.
I then tried several other bootable USB's on the UpBoard and those worked.
But the Vortexbox boot image only ends in the shell each time, do you have any ideas?
c0op3r
c0op3r
Make sure you use rufus AND make sure these settings are set from the following link. (it will change some when certain things are altered)
https://up-community.org/forum/ms-windows/321-how-to-get-started-with-installing-windows-10#874 -
Thank you for the reply, I ended up running Daphile (http://www.daphile.com/) instead.
So far it seems to be working perfectly. I will update the thread once the project is completed. -
Plex media server with flac files is a much better solution imo
