How to operate GPIO on and off in sysfs.Please help me
I have an UP2 Intel N4200 evaluation board.I use Ubilinux sysfs shell can operate GPIO on and off,reference https://wiki.up-community.org/Pinout_UP2.But after I installed Ubuntu 18.04, in the same way, no error was reported on the shell command, but in fact GPIO did not work.
[root@test-UP-APL01:/sys/class/gpio# echo 432 > export root@test-UP-APL01:/sys/class/gpio# cd gpio432 root@test-UP-APL01:/sys/class/gpio/gpio432# echo "out" > direction root@test-UP-APL01:/sys/class/gpio/gpio432# cat value 0 root@test-UP-APL01:/sys/class/gpio/gpio432# cat value 1 root@test-UP-APL01:/sys/class/gpio/gpio432# echo 1 > value root@test-UP-APL01:/sys/class/gpio/gpio432# cat /sys/kernel/debug/gpio gpiochip3: GPIOs 267-309, parent: platform/INT3452:03, INT3452:03: gpiochip2: GPIOs 310-356, parent: platform/INT3452:02, INT3452:02: gpiochip1: GPIOs 357-433, parent: platform/INT3452:01, INT3452:01: gpio-432 ( |sysfs ) out hi gpiochip0: GPIOs 434-511, parent: platform/INT3452:00, INT3452:00: root@test-UP-APL01:/sys/class/gpio/gpio432#
I really can’t find the problem point, how to operate GPIO on and off in sysfs.Please help me,Thank you
  • from the formatting of your message I cannot really understand the problem.
    Can you please attach a log file or use the correct spacing/carriage return?
    If you have installed the kernel correctly from our wiki page: https://wiki.up-community.org/Ubuntu_18.04
    After reboot please verify the system has booted correctly with that kernel: uname -a
