no devices found when trying to run a demo using the option -d HDDL
OAlzaibaq
OAlzaibaq New Member Posts: 3
I have been having this issue since around a week and still have no idea how to solve it.
Here is the last part of the output I get when I run any one of the demos by running sudo -E ./demo_squeezenet_download_convert_run.sh -d HDDL:
Run Inference Engine classification sample
Run ./classification_sample_async -d HDDL -i /opt/intel/openvino_2020.2.120/deployment_tools/demo/car.png -m /home/nvr/openvino_models/ir/public/squeezenet1.1/FP16/squeezenet1.1.xml
[ INFO ] InferenceEngine:
API version ............ 2.1
Build .................. 42025
Description ....... API
[ INFO ] Files were added: 1
[ INFO ]     /opt/intel/openvino_2020.2.120/deployment_tools/demo/car.png
[ INFO ] Creating Inference Engine
HDDL
HDDLPlugin version ......... 2.1
Build ........... custom_releases/2020/2_d8830cd2bfe6199444299be1d92b281e5459f195
[ INFO ] Loading network files
[ INFO ] Preparing input blobs
[ WARNING ] Image is resized from (787, 259) to (227, 227)
[ INFO ] Batch size is 1
[ INFO ] Loading model to the device
[14:12:30.8923][24788]I[main.cpp:243] ## HDDL_INSTALL_DIR: /opt/intel/openvino_2020.2.120/deployment_tools/inference_engine/external/hddl
[14:12:30.8927][24788]I[main.cpp:245] Config file '/opt/intel/openvino_2020.2.120/deployment_tools/inference_engine/external/hddl/config/hddl_service.config' has been loaded
[14:12:30.8947][24788]I[FileHelper.cpp:272] Set file:/var/tmp/hddl_service_alive.mutex owner: user-'no_change', group-'users', mode-'0660'
[14:12:30.8949][24788]I[FileHelper.cpp:272] Set file:/var/tmp/hddl_service_ready.mutex owner: user-'no_change', group-'users', mode-'0660'
[14:12:30.8951][24788]I[FileHelper.cpp:272] Set file:/var/tmp/hddl_start_exit.mutex owner: user-'no_change', group-'users', mode-'0660'
[14:12:30.8994][24788]I[AutobootStarter.cpp:156] Info: No running autoboot process. Start autoboot daemon...
[14:12:30.9794][24792]I[FileHelper.cpp:272] Set file:/var/tmp/hddl_autoboot_alive.mutex owner: user-'no_change', group-'users', mode-'0660'
[14:12:30.9802][24792]I[FileHelper.cpp:272] Set file:/var/tmp/hddl_autoboot_ready.mutex owner: user-'no_change', group-'users', mode-'0660'
[14:12:30.9807][24792]I[FileHelper.cpp:272] Set file:/var/tmp/hddl_autoboot_start_exit.mutex owner: user-'no_change', group-'users', mode-'0660'
[14:12:30.9812][24792]I[FileHelper.cpp:272] Set file:/tmp/hddl_autoboot_device.map owner: user-'no_change', group-'users', mode-'0660'
[14:12:30.9838][24792]I[AutoBoot.cpp:308] [Firmware Config] deviceName=default deviceNum=0 firmwarePath=/opt/intel/openvino_2020.2.120/deployment_tools/inference_engine/external/hddl/lib/mvnc/usb-ma2x8x.mvcmd
[14:12:51.3108][24788]I[AutobootStarter.cpp:85] Info: Autoboot is running.
[14:12:51.3492][24788]I[TaskSchedulerFactory.cpp:45] Info: ## TaskSchedulerFactory ## Created Polling Task-Scheduler.
[14:12:51.3514][24788]I[FileHelper.cpp:272] Set file:/var/tmp/hddl_snapshot.sock owner: user-'no_change', group-'users', mode-'0660'
[14:12:51.3557][24788]I[FileHelper.cpp:272] Set file:/var/tmp/hddl_service.sock owner: user-'no_change', group-'users', mode-'0660'
[14:12:51.3564][24788]I[MessageDispatcher.cpp:87] Message Dispatcher initialization finished
[14:12:51.3567][24788]I[main.cpp:103] SERVICE IS READY ...
[14:12:51.4492][24847]I[ClientManager.cpp:159] client(id:1) registered: clientName=HDDLPlugin socket=2
[14:12:51.4813][24847]I[ClientManager.cpp:189] client(id:1) unregistered: clientName=HDDLPlugin socket=2
[ ERROR ] no devices found
Error on or near line 217; exiting with status 1
when I run the python script hello_query_device.py, both the CPU and HDDL devices appear:
/opt/intel/openvino_2020.2.120/deployment_tools/inference_engine/samples/python/hello_query_device$ python3 hello_query_device.py
Available devices:
Device: CPU
Metrics:
AVAILABLE_DEVICES:
SUPPORTED_METRICS: AVAILABLE_DEVICES, SUPPORTED_METRICS, FULL_DEVICE_NAME, OPTIMIZATION_CAPABILITIES, SUPPORTED_CONFIG_KEYS, RANGE_FOR_ASYNC_INFER_REQUESTS, RANGE_FOR_STREAMS
FULL_DEVICE_NAME:       Intel(R) Celeron(R) CPU  J1900  @ 1.99GHz
OPTIMIZATION_CAPABILITIES: FP32, INT8, BIN
SUPPORTED_CONFIG_KEYS: CPU_BIND_THREAD, CPU_THREADS_NUM, CPU_THROUGHPUT_STREAMS, DUMP_EXEC_GRAPH_AS_DOT, DYN_BATCH_ENABLED, DYN_BATCH_LIMIT, EXCLUSIVE_ASYNC_REQUESTS, PERF_COUNT
RANGE_FOR_ASYNC_INFER_REQUESTS: 1, 1, 1
RANGE_FOR_STREAMS: 1, 4
Default values for device configuration keys:
CPU_BIND_THREAD: YES
CPU_THREADS_NUM: 0
CPU_THROUGHPUT_STREAMS: 1
DUMP_EXEC_GRAPH_AS_DOT:
DYN_BATCH_ENABLED: NO
DYN_BATCH_LIMIT: 0
EXCLUSIVE_ASYNC_REQUESTS: NO
PERF_COUNT: NO
Device: HDDL
Metrics:
AVAILABLE_DEVICES:
SUPPORTED_METRICS: AVAILABLE_DEVICES, SUPPORTED_METRICS, SUPPORTED_CONFIG_KEYS, FULL_DEVICE_NAME, OPTIMIZATION_CAPABILITIES, RANGE_FOR_ASYNC_INFER_REQUESTS, VPU_HDDL_DEVICE_NUM, VPU_HDDL_DEVICE_NAME, VPU_HDDL_DEVICE_THERMAL, VPU_HDDL_DEVICE_ID, VPU_HDDL_DEVICE_SUBCLASS, VPU_HDDL_DEVICE_MEMORY_TOTAL, VPU_HDDL_DEVICE_MEMORY_USED, VPU_HDDL_DEVICE_UTILIZATION, VPU_HDDL_DEVICE_TAG, VPU_HDDL_STREAM_ID
SUPPORTED_CONFIG_KEYS: PERF_COUNT, VPU_INPUT_NORM, VPU_INPUT_BIAS, VPU_HDDL_GRAPH_TAG, VPU_HDDL_STREAM_ID, VPU_HDDL_DEVICE_TAG, VPU_HDDL_BIND_DEVICE, VPU_HDDL_RUNTIME_PRIORITY, VPU_HDDL_USE_SGAD, VPU_COPY_OPTIMIZATION, LOG_LEVEL, VPU_IGNORE_UNKNOWN_LAYERS, VPU_HW_STAGES_OPTIMIZATION, VPU_NONE_LAYERS, VPU_NUMBER_OF_SHAVES, VPU_NUMBER_OF_CMX_SLICES, VPU_HW_INJECT_STAGES, VPU_HW_POOL_CONV_MERGE, VPU_HW_STAGES_OPTIMIZATION, EXCLUSIVE_ASYNC_REQUESTS
FULL_DEVICE_NAME: Intel Vision Accelerator Design with Intel Movidius VPUs
OPTIMIZATION_CAPABILITIES: FP16
RANGE_FOR_ASYNC_INFER_REQUESTS: 0, 2000, 1
VPU_HDDL_DEVICE_NUM: 0
VPU_HDDL_DEVICE_NAME:
VPU_HDDL_DEVICE_THERMAL:
VPU_HDDL_DEVICE_ID:
VPU_HDDL_DEVICE_SUBCLASS:
VPU_HDDL_DEVICE_MEMORY_TOTAL:
VPU_HDDL_DEVICE_MEMORY_USED:
VPU_HDDL_DEVICE_UTILIZATION:
VPU_HDDL_DEVICE_TAG:
VPU_HDDL_STREAM_ID:
PERF_COUNT:
VPU_INPUT_NORM:
VPU_INPUT_BIAS:
VPU_HDDL_GRAPH_TAG:
VPU_HDDL_STREAM_ID:
VPU_HDDL_BIND_DEVICE:
VPU_HDDL_RUNTIME_PRIORITY:
VPU_HDDL_USE_SGAD:
VPU_COPY_OPTIMIZATION:
LOG_LEVEL:
VPU_IGNORE_UNKNOWN_LAYERS:
VPU_HW_STAGES_OPTIMIZATION:
VPU_NONE_LAYERS:
VPU_NUMBER_OF_SHAVES:
VPU_NUMBER_OF_CMX_SLICES:
VPU_HW_INJECT_STAGES:
VPU_HW_POOL_CONV_MERGE:
and the process 'hddldaemon' logs the following two lines:
[09:33:45.7696][24847]I[ClientManager.cpp:159] client(id:6) registered: clientName=HDDLPluginForQuery socket=2
[09:33:45.7955][24847]I[ClientManager.cpp:189] client(id:6) unregistered: clientName=HDDLPluginForQuery socket=2
When I run lsusb, the mpcie does not appear. I have the mpcie connected
to the mpcie slot on the motherboard.
The demo runs successfully using the option -d CPU (intel J1900)
The demo also runs successfully using the option -d MYRIAD, as I have a
neural compute stick 2 (NCS2)
I am using ubuntu 18.04 and openvino 2020.2.120
One last note: I was able to run the demo successfully on the HDDL only
once, and immediately after that, I ran the same command and the same
error above came back.
